Control pan with tilt disable [fixed]
create lighting scenes
MikeyMo16
Post by MikeyMo16 »
This might not be the right place to post because it's concerning Midi sliders but here we go. I am trying to create two sliders, one for pan and another for tilt. The problem is that every time I attempt to create the scenes it causes one of the sliders to stay at the value 0. For instance, for my pan slider I have 127 scenes and each step is an odd number 3-255. When I add the values to the steps the tilt gets set at 0. I can not disable the tilt channel with out disabling the pan channel. The result is conflicting sliders in live when I want to mix pan and tilt. Does anyone know how I can individually set just the pan or just the tilt? Any help would be greatly appreciated. Thank you very much.
Re: Pan/Tilt problems
It is not possible to drive X with Y disable, and vice versa.
MikeyMo16
Re: Control pan with tilt disable
Post by MikeyMo16 »
Why? Whats the reason for that?
In the source code, "pan / tilt / pan fine / tilt fine" have always been considered as one single entity.
MikeyMo16
Post by MikeyMo16 »
Any way to modify that? Would be great to grab either pan or tilt on the fly, especially with inverted fixtures.
Not in a near future ; sorry for that.
"pan / tilt / pan fine / tilt fine" must stay one entity for hundreds other important reasons.
Re: Control pan with tilt disable [fixed]
In next software version (or beta), it will be possible to drive pan with tilt disable (and vice versa).
eedetail
Post by eedetail »
In setup, change the value of the y channel from "Y" to something else... I used Z.
That will break the link between X and Y and let you run one channel without
enabling the other.
ryvanz
Post by ryvanz »
eedetail wrote:In setup, change the value of the y channel from "Y" to something else... I used Z.
enabling the other.
Dammit that's brilliant! Not sure why I didn't think of it myself.
ryvanz
Post by ryvanz »
support wrote:In next software version (or beta), it will be possible to drive pan with tilt disable (and vice versa).
The current version was released March 30th. Has this fix been included in that version?
THanks!
Return to “Editor”
