Can not see lights beams [fixed]
braddj1
Post by braddj1 »
I've got everything set-up i can use lights On dmx no probs but when I go on to 3d I can see the lights moving but I cant see any beams of light can you help me out so I can set-up shows without bring my lights in every time please
Re: Can not see lights beams
Please look at the "demo_show".
You could compare the "working" fixtures with your fixtures.
braddj1
Post by braddj1 »
OK thank you for that I tried imove5s worked no problem but I had to make 1 up for imove7s and i still can not get the beam to work everything is the same just have 1 extra channel for rotating gobo has there been a fixture been made up for isolution imove7s at all if there has can you help with this
thank you
brad
Dumbmonkey
Post by Dumbmonkey »
I am also having issues seeing light beams and I cannot figure out the issue. I opened the demo show and had no problems with 3d view. I am using 24 tri par pro color changers and 6 q wash 260 with a MacBook. Any suggestions as to what I may be overlooking? For the record the actual physical light show is working fine. Do I need to import different profiles for the fixtures?
Please post the personality files ; we will check them.
Dumbmonkey
I am using the profiles available from the Chauvet web site .
Slimpar Pro Tri (9 ch):
ViewType = VIEW_TYPE_COLOR_CHANGER
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel = dimmer
dimmer,0,255
Channel = red
Red,0,255
Channel = green
Green,0,255
Channel = blue
Blue,0,255
Channel = color_macro
no_function,0,10 red 100%/green up/blue 0%,11,30 red down/green100%/blue 0%,31,50 red0%/green100%/blue up,51,70 red0%/green down/blue 100%,71,90 red up/green0%/blue100%,91,110 red 100%/green0%/blue down,111,130 red 100%/green up/blue up,131,150 red down/green down/blue100%,151,170 red 100%/green100%/blue100%,171,200 White1: 3200K,201,205 White 2: 3400K,206,210 White 3: 4200K,211,215 White 4: 4900K,216,220 White 5: 5600K,221,225 White 6: 5900K,226,230 White 7: 6500K,231,235 White 8: 7200K,236,240 White 9: 8000K,241,245 White 10: 8500K,246,250 White 11: 1000K,251,255
Channel = strobe_effect
Strobe off,0,9 strobe,10,255
Channel = effect_macro
no_function,0,51 Auto program 1,52,101 Auto program 2,102,152 Auto program 3,153,203 Auto program 4,204,254 Auto program 5,255,255
Channel = strobe_speed
Auto program speed ,0,255
Channel = dimmer
Default dimmer speed,0,51 Linear dimmer,52,101 Non-linear dimmer 1,102,152 Non-linear dimmer 2,153,203 Non-linear dimmer 3,204,255
And Q-Wash 260-LED (Advanced)
ViewType = VIEW_TYPE_HEAD_WASH
ViewPower = VIEW_POWER_LED60W
ViewAnglePan = 540
ViewAngleTilt = 260
ViewAngleBeam = 26
Channel = pan
Channel = upan
Channel = tilt
Channel = utilt
Channel = pantilt_speed
Channel = red
Channel = green
Channel = blue
no_function,0,5 macro_1,6,10 macro_2,11,30 macro_3,31,50 macro_4,51,70 macro_5,71,90 macro_6,91,110 macro_7,111,130 macro_8,131,150 macro_9,151,170 macro_10,171,200 macro_11,201,205 macro_12,206,210 macro_13,211,215 macro_14,216,220 macro_15,221,225 macro_16,226,230 macro_17,231,235 macro_18,236,240 macro_19,241,245 macro_20,246,250 macro_1,251,255
Channel = dimmer
Channel = strobe_dimmer
no_function,0,9 dimmer,10,255
Channel = speed_control
return settings,0,9 Minimum_value,10,29 dimmer,30,69 dimmer,70,129 ???,130,189 dimmer,190,255
Channel = control
no_function,0,19 blackout_moves,20,39 blackout_changes,40,59 auto1,60,79 auto2,80,99 audio1,100,119 audio2,120,139 custom,140,149 auto,150,159 custom,160,169 custom,170,179 no_function,180,199 reset,200,219 no_function,220,255
These profiles have some errors.
Please use the attached profiles.
SlimPAR Pro Tri (9CH).txt
(1.33 KiB) Downloaded 1187 times
Q-Wash 260-LED (Advanced).txt
(1.21 KiB) Downloaded 1227 times
