The Digital Driver Signature issue help option with DJ Mikey
directsound
Post by directsound »
Ok I now have a 64 bit computer and I tried to use my cable with 6.0 with no luck due to the The Digital Driver Signature
driver issue and I tried all of the ways on the FAQ's page on The Digital Driver Signature post and none worked so I did find a fix for me I used
http://www.ngohq.com/home.php?page=File ... dwn_id=826
This web site software down load it puts your computer in Driver test mode so you can use driver without a cert. I would try the other ways first but if all else fails here is another way I’m not sure how stable yet as I just installed it but so far so good.
To download it is tricky to stay away from all of the paid advertisement but there is a little ****Agree **** DO NOT hit the START DOWNLOAD button!!!!! word towards the bottom to You agree to indemnify and hold this WEBSITE harmless from any and all damages, risk and liabilities. after you agree it will download and like I said it worked for me ...It put a little text by my clock and says something like In test mode 123 or something like that when I installed it I ran the program and then you have options to turn it on or exit ...you then need to do a full restart to take effect
I hope this helps if all else fails
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
http://www.directsound.com
Re: The Digital Driver Signature issue help option with DJ Mikey
Thank you for this info.
In fact, we knew it already but we have prefered to propose the "ReadyDriverPlus" solution (which is supposed to work on all Windows 7 64bits computers).
directsound
So far so good,,,I have been busy with a Photo Booth build but I am going to now use the usb 100 to control the camera strobs and booth lighting
thanks for everything! When is the new 6.0 finle coming out with all the bells ?
thanks for your time
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
We have a beta version (with Timeline).
We will test it during a big show this week in Germany.
We should release a beta version with Timeline before the end of this month.
For info, we have a very difficult job to adapt ScreenControl (our media player) with Quicktime for MacOS ; it is not 100% ready.
The Windows part is ready, but we would like the release a version ok for both OS.
directsound
Sounds great good luck at the show and I cant wait to play with the new version
thanks
for your time
MM
Thanks,
From DJ Mikey Mike
Return to “Windows”
