Chauvet ColorPalettes and Elation DesignSpot [fixed]
Simply Jay
Post by Simply Jay »
I just download 6.01. I am starting to program some scenes for my lightshows, however, I when trying to have the chauvet colorpalettes in 27 CH mode picking a color only controls on of the faders. It would have to manipulate 8 faders to get the whole palette. Another thing I see is that Elation Designspot profile in 3D view is not accurate with Iris fader, when its set to 0 the beam should be open; however in 3d view it shows as if the shutter is closed.
Re: Chauvet ColorPalettes and Elation DesignSpot [moved]
Editor is able to manage only one RGB colorwheel per fixture.
There is a workaround to use the colorwheel for all rgb channels: create separate fixtures with only RGB channels.
Regarding the problem of reversed iris:
- edit the fixture in Setup
- check the option "3DView -> reverse iris"
Return to “Setup”
