3DView shows only one beam per fixture
To workaround this, you can try to split the fixture in "single beam" fixtures, then you can see all beams.
Often this brings a new issue, because some channels are commun for all beams (like shutter with strobe and dimmer).
This means "shutter" actions will not be visible on all beams.
