How to add walls in the stage ? [fixed]
SoundXtreme
Post by SoundXtreme »
I am a new Showxpress user user and I am trying to build a stage similar to the one attached. The back end of the stage has side walls, back wall and roof however I can not get the stage walls to align up with my design. Perhaps I should have started with the stage wall settings first and then build my towers around that? I hope there's a short cut to fix this!
I know this explanation is probably not so good but I am attaching images of my "out of proportion" design and the real stage. Note that the grey back stage area needs to shift to the right and to the back.
Regards
Dewald
SoundXtreme
Re: Building Stage in 3D
Here is the 3D stage that I am trying to fix the back part
We suggest you to add the object "_special/picture_panel".
In order to show a wall, it is possible to put a picture over this object:
- open "Object settings"
- select the object
- right click on the object in the 3D view to get the popup menu
- select "Picture"
SoundXtreme
Thank you its working great!
