Command Bar and Right-Click Controls [closed]
andrewb
Post by andrewb »
I am having an issue with the command bar and right-click controls in ShowXpress.
When using the right-click controls in the Editor and Live applications, the responding drop down boxes are reduced to small gray bars. Because of this, I cannot access the command buttons of the sliders for the the Editor app and I am not able to add/remove items from pages on the Live screen.
Also, the same problem occurs when trying to access the drop down boxes on the command bar of each screen.
I am running Windows XP with ShowXpress software version 6.29.
Thanks in advance for any help that can be provided!
Re: RE: Command Bar and Right-Click Controls
Is there a specific theme in your XP os ?
Can you please send us some screenshots of this problem ?
andrewb
Post by andrewb »
support wrote:Is there a specific theme in your XP os ?
I am running the default XP theme
support wrote:Can you please send us some screenshots of this problem ?
Yes and I have attached a few with this post:
Could you please tell us the XP os "pack" version (Pack 1, Pack 2, Pack 3) ? (you can see that in the "System Properties" > tab "General")
Is the "os automatic update" activated ?
In the software folder, there are the following folders: "3DView", "ControlBoard", "Editor", ...
Could you also email us a ZIP file of the complete folder "Editor" (size of ZIP file should be a bit more than 2Mb) ?
andrewb
Post by andrewb »
I am running Service Pack 3 and yes, automatic updates are currently applied.
For me to send an email, can I have the appropriate address?
Thanks!
When we run Editor from your folder, we do not see this problem.
May be your lightshow is the cause (?) Could you please send us a backup of your current lightshow ?
Could you also confirm that the software language is set to English/USA ? Or even better, please send us this file "C:\Documents and Settings\YourAccountName\TheLightingController\param.ini"
andrewb
Post by andrewb »
Yes, I can send the param.ini text.
Is the lightshow the folder that contains the text file?
tomrbland
Post by tomrbland »
andrewb wrote:Is the lightshow the folder that contains the text file?
In ControlBoard go to "export a light show" (middle one on the right)
andrewb
Post by andrewb »
Thanks tomrbland!
