Live Board Quits
SkateInn
Live Board Quits
Post by SkateInn »
When adding a new page to #2 board it quits along with the editor. We are using showexpress with Mac os X. It is also quitting while using preset dimming curves in the Generator/Editor.
Re: Live Board Quits
Please tell us:
- the version of the software (if not 6.29, please download/install it and try again ; we can help only for the newest version)
- the exact version of your Mac operating system
- does this problem happen with an empty lightshow, or does it happen exclusively with a specific lightshow (if exclusively with a specific lightshow, please send us a backup of the lightshow ; we will check it) ?
SkateInn
Post by SkateInn »
We are using 6.27 and Mac OS X snow leopard. The Live shut down occurs with populated light show. The Generator issue occurs when we select the pan and tilt on an factory preset dimming curves. However, the generator works fine when we create our own curves. If we download and install the latest version, will we lose any of our recent created scenes/shows? By the way, we are controlling four Q-Spot 260s and are very pleased with their performance.
We are not able to fix bugs of an old software version.
Please download and install the current version (V6.29), and let us know if the same problem is still present.
You will not lose any lightshow with software upgrade, because the lightshows are stored in a different location than the software folder.
SkateInn
Post by SkateInn »
We have updated to V6.29. Using the Generator preset curves and clicking on the pan and tilt "check box" it blows up.
Please see below dump file.
Process: Editor [428]
Path: /Users/tallahasseeskateinn/Desktop/ShowXpress/Editor/Editor.app/Contents/MacOS/Editor
Identifier: Editor
Version: ??? (0.1)
Code Type: X86 (Native)
Parent Process: launchd [114]
Date/Time: 2011-10-22 18:32:34.930 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 154278 sec
Crashes Since Last Report: 9
Per-App Crashes Since Last Report: 16
Anonymous UUID: DDD75C5A-2BF9-4638-B27D-90A08CC93FAC
Exception Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: EXC_I386_DIV (divide by zero)
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 Editor 0x0001c0dc 0x1000 + 110812
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x97584382 kevent + 10
1 libSystem.B.dylib 0x97584a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x97583f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x97583cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x97583781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x975835c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x97583412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x975839a8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x975835c6 start_wqthread + 30
Thread 3: com.apple.CFSocket.private
0 libSystem.B.dylib 0x9757cac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x97b3bc53 __CFSocketManager + 1091
2 libSystem.B.dylib 0x9758b259 _pthread_start + 345
3 libSystem.B.dylib 0x9758b0de thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00000000 ecx: 0x0030c524 edx: 0x00000000
edi: 0xbffffaf0 esi: 0xbffffafc ebp: 0x01022020 esp: 0xbffff9b0
ss: 0x0000001f efl: 0x00010202 eip: 0x0001c0dc cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x0070b868
Binary Images:
0x1000 - 0x77feb +Editor ??? (0.1) <7682C679-1131-3365-9A18-234F27F30CDC> /Users/tallahasseeskateinn/Desktop/ShowXpress/Editor/Editor.app/Contents/MacOS/Editor
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <283EE026-C0FE-1FF9-DB81-BFB155793157> /usr/lib/dyld
0x9000b000 - 0x9006ffff com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x90070000 - 0x900a1ff7 libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x90205000 - 0x9020bff7 libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x90888000 - 0x9088fff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90890000 - 0x90896fff com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x90897000 - 0x90911fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x90912000 - 0x90992feb com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90993000 - 0x909cefeb libFontRegistry.dylib ??? (???) <AD45365E-A3EA-62B8-A288-1E13DBA22B1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x909cf000 - 0x90a02ff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x90a03000 - 0x90a95fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90a96000 - 0x90aa4ff7 com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90ae6000 - 0x90c68fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
0x90ca3000 - 0x90cc5fef com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x90d1a000 - 0x90e26ff7 libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x90f2e000 - 0x91110fff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x91118000 - 0x9125bfef com.apple.QTKit 7.7 (1787) <3B47A1A0-7AB5-C1C9-42DE-5993D1012D47> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9125c000 - 0x91a4b557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x91a4c000 - 0x91a6dfe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91a6e000 - 0x91a7cfe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <E1B922F4-23DC-467E-631F-7E1B9C9F51CB> /usr/lib/libz.1.dylib
0x91a7d000 - 0x91acdff7 com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x91ace000 - 0x91adaff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x91b4d000 - 0x92430ff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92431000 - 0x924defe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x924df000 - 0x925aafef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x925ab000 - 0x9262dffb SecurityFoundation 36840.0.0 (compatibility 1.0.0) <D7A06F33-723C-81DB-CAA3-EB19C570928C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9262e000 - 0x92646ff7 com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x926a5000 - 0x927a7fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x928e0000 - 0x928eafe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x928f9000 - 0x92946feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x92969000 - 0x929c6ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x929c7000 - 0x929c7ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93aa5000 - 0x93abafff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93b2a000 - 0x93b6cff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <1AE34B00-8A62-1E51-935F-BB3F0E4BE50F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x93b72000 - 0x93de3fef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x93de4000 - 0x93de4ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93de5000 - 0x93df5ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
0x93df6000 - 0x93e1aff7 libJPEG.dylib ??? (???) <EA97DEC5-6E16-B51C-BF55-F6E8D23526AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93e1b000 - 0x9413bff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94799000 - 0x947fafe7 com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9480e000 - 0x9480eff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94b3a000 - 0x94c67ffb com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x94c8a000 - 0x94cf4fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x94d91000 - 0x94fdaffb com.apple.JavaScriptCore 6534.51 (6534.51.21) <EA8C05E3-4719-B3FA-E17E-EC9BBC09F5B2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x94fdb000 - 0x9542cfef com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9542d000 - 0x954c8fe7 com.apple.ApplicationServices.ATS 275.19 (???) <9FA31967-CF14-B033-EB8D-570561D12A13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x954c9000 - 0x9551cff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9552b000 - 0x95538ff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95539000 - 0x95544ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95545000 - 0x95673fe7 com.apple.CoreData 102.1 (251) <0C2636F3-CCB4-5ED9-1D3E-5AE36BE57071> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x95674000 - 0x958d9feb com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x958da000 - 0x95a9cfeb com.apple.ImageIO.framework 3.0.4 (3.0.4) <027F55DF-7E4E-2310-1536-3F470CB8847B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95a9d000 - 0x95aaeff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95aaf000 - 0x95ab7ff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x95af9000 - 0x95b0dfe7 libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
0x95bb8000 - 0x95c50fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95c51000 - 0x95c77ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x95f7e000 - 0x9605efe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x960d4000 - 0x9614dff7 com.apple.PDFKit 2.5.1 (2.5.1) <4C374867-71B8-B202-ADDA-9985B4379470> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x9614e000 - 0x96153ff7 com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9615c000 - 0x9625dfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
0x96297000 - 0x962d4ff7 com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x96338000 - 0x9676dff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x974d3000 - 0x974d6fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x974f9000 - 0x97537ff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x97551000 - 0x9755cff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9755d000 - 0x97704ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x97705000 - 0x977a2fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x977a3000 - 0x977b5ff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x977b6000 - 0x977b6ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x977b7000 - 0x977b9ff7 com.apple.securityhi 4.0 (36638) <E8A89905-2DDD-674D-BA2F-AB7574825AF2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9789b000 - 0x978dffe7 com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x978e0000 - 0x97abefeb libType1Scaler.dylib ??? (???) <59FE1036-1BC2-1A8E-F7C6-E0CC15A4D6D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x97abf000 - 0x97c3afe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x97c3b000 - 0x97d15fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x97d16000 - 0x97e18fef com.apple.MeshKitIO 1.1 (49.2) <EC52D0C5-5291-441D-F137-8E4DD60F0E25> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x97e19000 - 0x97ec1ffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x97ec2000 - 0x97ef8fff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x97fcb000 - 0x97fccff7 com.apple.TrustEvaluationAgent 1.1 (1) <06484720-AB50-6FD9-B5BF-05F5A640C9E5> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x97fcd000 - 0x97fcdff7 com.apple.Carbon 150 (152) <EA72D982-AA3E-D1CF-7375-8CB078658542> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x97fce000 - 0x98015ffb com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x98016000 - 0x98057ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x98058000 - 0x980c6ff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x982fa000 - 0x98665ff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9869b000 - 0x9869dff7 libRadiance.dylib ??? (???) <5920EB69-8D7F-5EFD-70AD-590FCB5C9E6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9869e000 - 0x986a4fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x986a5000 - 0x986e2ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x986e3000 - 0x98752ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <B3DEACA1-9375-CF8F-0898-AA2C5F8159DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x98753000 - 0x98767ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x98768000 - 0x98769ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <1DD14B2E-E466-1A45-5CF7-947766F0ECD9> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x987e2000 - 0x987e2ff7 com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x989c0000 - 0x98ce4fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x98ce5000 - 0x98ce5ff7 com.apple.quartzframework 1.5 (1.5) <7DD4EBF1-60C4-9329-08EF-6E59731D9430> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x98ce6000 - 0x98ce6ff7 liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
0x98ce7000 - 0x98da3fff com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98da4000 - 0x98dd4ff7 com.apple.MeshKit 1.1 (49.2) <464BD81C-9970-FBF5-507F-3EEBD020A967> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x98dd5000 - 0x98e1bff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x98e1c000 - 0x992d7ff7 com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x992d8000 - 0x99391fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x99392000 - 0x993b1ff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x993b2000 - 0x993f5ff7 libGLU.dylib ??? (???) <FB26DD53-03F4-A7D7-8804-EBC5B3B37FA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x993f6000 - 0x99412fe3 com.apple.openscripting 1.3.1 (???) <0E6B81D1-C1BD-1B5F-836F-256E6701B5DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x99413000 - 0x9941cff7 com.apple.DiskArbitration 2.3 (2.3) <6AA6DDF6-AFC3-BBDB-751A-64AE3580A49E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9941d000 - 0x9949aff7 com.apple.iLifeMediaBrowser 2.5.5 (468.2.2) <459C8983-EAC4-7067-3355-5299D111D339> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x9949b000 - 0x996c6ff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x996dd000 - 0x996e7ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <90C38107-AEE7-AE55-5C51-28D129B19BCD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x996e8000 - 0x996ebffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x99724000 - 0x9977efe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x997c7000 - 0x997e2ff7 libPng.dylib ??? (???) <25DF2360-BFD3-0165-51AC-0BDAF7899DEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x99858000 - 0x99882ff7 com.apple.shortcut 1.1 (1.1) <08A1868D-FEF4-8FB3-D814-79385DCBEC7D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x99883000 - 0x99887ff7 libGIF.dylib ??? (???) <2123645B-AC89-C4E2-8757-85834CAE3DD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9988e000 - 0x9993afe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9993b000 - 0x9996efff libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9996f000 - 0x99970ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x99971000 - 0x99974ff7 libCoreVMClient.dylib ??? (???) <F58BDFC1-7408-53C8-0B08-48BA2F25CA43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x999a9000 - 0x999adff7 libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x99add000 - 0x99b33ff7 com.apple.MeshKitRuntime 1.1 (49.2) <4B41E225-69AC-6EFA-190E-DC6A4BD8109E> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x99b85000 - 0x99b8fff7 com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x99b90000 - 0x99b94ff7 IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x99b95000 - 0x99bd9ff3 com.apple.coreui 2 (114) <1A3C3B7F-3837-6477-3114-47F6BFD56CB2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x99cf6000 - 0x99daefeb libFontParser.dylib ??? (???) <D57D3834-9395-FD58-092A-49B3708E8C89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x99daf000 - 0x99df8fe7 libTIFF.dylib ??? (???) <579DC328-567D-A74C-4BCE-1D1C729E3F6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x99e0c000 - 0x99e51ff7 com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x99ef3000 - 0x99ef3ff7 com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x99f2d000 - 0x99f55ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
0x99f56000 - 0x99f76fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <584B2B30-DC65-6930-F59F-C49FD5604B67> /usr/lib/libresolv.9.dylib
0x99f77000 - 0x9a271fef com.apple.QuickTime 7.6.6 (1787) <AC48EAD9-7201-7CE6-C826-41B12963FECF> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9a272000 - 0x9a688ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9a689000 - 0x9a6b0ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <F45520B0-6B27-CD57-54B1-203FE32120DA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x9a6b1000 - 0x9a7eefe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9a7ef000 - 0x9a829ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
0x9a82c000 - 0x9a86fff7 com.apple.NavigationServices 3.5.4 (182) <FE19D51B-233A-69EC-9E36-B89D0EA438C1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9a8c2000 - 0x9a8d2ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <95DC4010-ECC4-3A75-5DEE-11BB2AE895EE> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x9a8d3000 - 0x9a8d6ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9a8d7000 - 0x9a952fff com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9a96c000 - 0x9aa1aff3 com.apple.ink.framework 1.3.3 (107) <E215794C-F3E9-C067-8882-9054796DDA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9aafa000 - 0x9ab52fe7 com.apple.datadetectorscore 2.0 (80.7) <3830B574-3B0B-76DA-390D-702D908A71F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: iMac11,2, BootROM IM112.0057.B00, 2 processors, Intel Core i3, 3.06 GHz, 4 GB, SMC 1.64f5
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST3500418AS, 465.76 GB
Serial ATA Device: PIONEER DVD-RW DVRTS09, 4.93 GB
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1006, 0xfd130000 / 5
USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0220, 0xfd132000 / 6
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 / 4
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd110000 / 3
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000 / 7
May be need your lightshow to reproduce it (?)
Does this problem happen also with an empty new lightshow ?
Return to “General”
