[6.01] Unable to select "Par Can" in 3DView section [fixed]
kbrkr
Post by kbrkr »
If I setup a fixture as a PAR CAN under 3DView drop down box, and then decide I want to change it to color changer, I cannot. The PAR CAN Drop down just drops down displaying ONLY the PAR CAN selection and no other values in the list. Is this intended behavior or a bug?
Re: BUG: Unable to change fixture from Par Can
This is a bug.
Fixed in fix files.
Return to “Setup”
