Crashing on Sonoma
Re: Crashing on Sonoma
The fix for V9.3.14 is online.
mcreim
Post by mcreim »
I had the exact same problem. Lightning Controller crashed even during live sessions.
I use a Mac Studio with M1 Ultra, latest Sonoma.
The Lightning Controller is remote controlled via companion app which runs on a second mac (mac mini M1, latest Sonoma)
I found out the following:
Using the latest Lightning Controller Software (9.3.15, Intel binary with the latest patch and "Do not use WebSocket" checked) and companion app 2.4.2 on the mac mini seems to work. It now runs for hours without crashing.
Using companion app 3.2.2 (the latest) the crashes seem to happen randomly.
companion app 3.2.2 also tells me that the module for controlling lightning controller is not supported by 3.x and has to be updated.
Hope this helps.
Best Michael
Thank you for this clear report.
We will take a look at that asap.
lockhap
Post by lockhap »
Has 9.3.14 been released? I am still crashing when attempting to use an external device.
lockhap
Post by lockhap »
Please disregard the last post. I have installed 9.3.15 and updated Companion to test the connection crashing.
lockhap
Post by lockhap »
So running 9.3.15 does not resolve the crashing issue. Attaching the crash report.
------------------------------------- Translated Report (Full Report Below) -------------------------------------
Process: TheLightingController [2616]
Path: /Volumes/*/TheLightingController.app/Contents/MacOS/ TheLightingController
Identifier: Version:
Code Type: Parent Process: User ID:
TheLightingController 0.1
X86-64 (Translated) launchd [1]
503
Date/Time:
OS Version: Report Version: Anonymous UUID:
2024-07-26 11:32:23.1379 -0700 macOS 14.5 (23F79)
12
Time Awake Since Boot: 66000 seconds System Integrity Protection: enabled
Crashed Thread:
Exception Type: Exception Codes: Exception Codes:
11
EXC_BAD_ACCESS (SIGSEGV) KERN_INVALID_ADDRESS at 0x0000000000000000 0x0000000000000001, 0x0000000000000000
Termination Reason: Terminating Process:
Namespace SIGNAL, Code 11 Segmentation fault: 11 exc handler [2616]
0BF3B397-640F-88D5-1AAD-E585C58AA214
VM Region Info: 0 is not in any region. Bytes before following region: 4343558144 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD
REGION DETAIL
UNUSED SPACE AT START
__TEXT 102e57000-10311b000 [ 2832K] r-x/r-x SM=COW /
Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController Thread 0:: Dispatch queue: com.apple.main-thread
0 ???
1 libsystem_kernel.dylib
2 libsystem_c.dylib
3 TheLightingController
4 TheLightingController
5 TheLightingController
0x7ff89dad2a78 ???
0x7ff80d7f2e46 __semwait_signal + 10 0x7ff80d6e5a61 nanosleep + 199
0x103025c67 0x102e57000 + 1895527 0x102eb41ef 0x102e57000 + 381423 0x102f09a95 0x102e57000 + 731797
6 TheLightingController
7 TheLightingController
8 dyld
0x102e896f4 0x102e57000 + 206580
0x102e74360 0x102e57000 + 119648 0x2035f5366 start + 1942
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime
Thread 2:
0 ???
2 libsystem_c.dylib
6 libsystem_pthread.dylib
7 libsystem_pthread.dylib
0x7ff7ffdbe494 0x7ff7ffdba000 + 17556
0x7ff89dad2a78 ???
0x103025c67 0x102e57000 + 1895527 0x102e753fa 0x102e57000 + 123898 0x102fffa50 0x102e57000 + 1739344
0x7ff80d83018b _pthread_start + 99 0x7ff80d82bae3 thread_start + 15
Thread 3:: com.apple.NSEventThread
0 ???
2 libsystem_kernel.dylib
3 libsystem_kernel.dylib
4 libsystem_kernel.dylib
5 CoreFoundation
143
6 CoreFoundation
7 CoreFoundation
8 AppKit
9 libsystem_pthread.dylib
10 libsystem_pthread.dylib
Thread 4:
0 ???
2 libsystem_c.dylib
Thread 5:
0 ???
2 libsystem_pthread.dylib
0x7ff89dad2a78 ???
0x7ff80d7f03ce mach_msg2_trap + 10 0x7ff80d7fec88 mach_msg2_internal + 84 0x7ff80d7f7510 mach_msg_overwrite + 653 0x7ff80d7f06bd mach_msg + 19
0x7ff80d90d909 __CFRunLoopServiceMachPort +
0x7ff80d90c37c __CFRunLoopRun + 1371
0x7ff80d90b859 CFRunLoopRunSpecific + 557 0x7ff81103bbbc _NSEventThread + 122
0x7ff89dad2a78 ???
0x103025c67 0x102e57000 + 1895527 0x102eab395 0x102e57000 + 344981 0x102fffa50 0x102e57000 + 1739344
0x7ff89dad2a78 ???
0x7ff80d7f2f7a __psynch_cvwait + 10 0x7ff80d8306f3 _pthread_cond_wait + 1211
0x102fff73b 0x102e57000 + 1738555 0x102eae0d9 0x102e57000 + 356569
8 libsystem_pthread.dylib
0x102eab56a 0x102e57000 + 345450
0x102fffa50 0x102e57000 + 1739344 0x7ff80d83018b _pthread_start + 99 0x7ff80d82bae3 thread_start + 15
Thread 6:
0 ???
5 CoreMIDI
void*, int&) + 98
6 CoreMIDI
104
7 CoreMIDI
CADeprecated::XThread::RunHelper(void*) + 10
8 CoreMIDI 0x7ff828f06903 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 77
9 libsystem_pthread.dylib 10 libsystem_pthread.dylib
Thread 7:
0 ???
3 libsystem_c.dylib
8 TheLightingController
9 TheLightingController
10 libsystem_pthread.dylib 11 libsystem_pthread.dylib
Thread 8: 0 runtime
Thread 9: 0 runtime
Thread 10:
0 ???
2 libsystem_c.dylib
0x7ff89dad2a78 ???
0x7ff80d7f0e46 __open_nocancel + 10 0x7ff80d800858 open$NOCANCEL + 224 0x7ff80d6e8243 fopen + 71
0x10303f6ac 0x102e57000 + 2000556 0x10303f810 0x102e57000 + 2000912 0x102eaa579 0x102e57000 + 341369 0x102e973b1 0x102e57000 + 263089 0x102f50db4 0x102e57000 + 1023412 0x102fffa50 0x102e57000 + 1739344
0x7ff7ffddc94c 0x7ff7ffdba000 + 141644
0x7ff89dad2a78 ???
0x7ff89dad2a78 ???
0x7ff828ef7e52 XServerMachPort::ReceiveMessage(int&, 0x7ff828f078ba MIDIProcess::MIDIInPortThread::Run() + 0x7ff828f04ed6
Thread 11 Crashed: 0 ???
0x102f50e0d 0x102e57000 + 1023501
0x0???
Thread 11 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000060000331fe18 rcx: 0x000000030addc000
rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x00007fe9fdd0e6f0 rbp: 0x000000030addbfb0 rsp:
0x000000030addbf88
r8: 0xffffffffffffffff r9: 0x0000000000000042 r10: 0x0000000000000010 r11:
0x0000600002bf0df0
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x00006000027ba0a0
r15: 0x0000000103203ca8
rip: 0x0000000000000000 rfl: 0x0000000000000202
tmp0: 0x0000000000000000 tmp1: 0x0000000102fffa50 tmp2: 0x000000010350c99c
Binary Images:
0x2035ef000 - 0x20367ffff dyld (*) <baa6f02e-dff3-3562-8c99-
ea2820c91ad9> /usr/lib/dyld
0x10bee4000 - 0x10bf0ffff efk_hardware.dylib (*) <551047f4-3f3d-3722-b296-
aed4f64c1b3e> /Volumes/*/efk_hardware.dylib
0x10be8b000 - 0x10be97fff libobjc-trampolines.dylib (*) <a994ca6d-8d6a-312f-
a7d9-a1a01cb10e70> /usr/lib/libobjc-trampolines.dylib
0x7ff7ffdba000 - 0x7ff7ffde9fff runtime (*) <b091dec9-37ac-322a-bd9d-
fc5dc22b0082> /usr/libexec/rosetta/runtime
0x10b716000 - 0x10b769fff libRosettaRuntime (*) <8a85f070-3849-3b55-
adde-143cc5902f92> /Library/Apple/*/libRosettaRuntime 0x102e57000 - 0x10311afff TheLightingController (*)
<81e0d438-83c0-389d-9fd7-94215e83b8c3> /Volumes/*/TheLightingController.app/ Contents/MacOS/TheLightingController
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ??? 0x7ff80d7ef000 - 0x7ff80d829ff7 libsystem_kernel.dylib (*)
<13597eeb-2ea0-3d48-8be1-dfc4872a784b> /usr/lib/system/libsystem_kernel.dylib 0x7ff80d6d6000 - 0x7ff80d75dff7 libsystem_c.dylib (*)
<93fb3816-608b-33af-83d2-209b4bd673ad> /usr/lib/system/libsystem_c.dylib 0x7ff80d82a000 - 0x7ff80d835ff7 libsystem_pthread.dylib (*)
<25b2f3eb-07b4-3cb9-9457-2c26210c27c8> /usr/lib/system/libsystem_pthread.dylib 0x7ff80d891000 - 0x7ff80dd2affc com.apple.CoreFoundation (6.9) <a32f4005-
d666-32c2-8e52-f67fc64616e0> /System/Library/Frameworks/
CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff810e9f000 - 0x7ff8122cdff2 com.apple.AppKit (6.9) <33ecd3dc-c895-35e2-
a1fd-c1761b155964> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7ff828ec6000 - 0x7ff828f51ff5 com.apple.audio.midi.CoreMIDI (2.0) <cfc251d3-
dbe1-3faa-af28-a2c43a47e0e3> /System/Library/Frameworks/CoreMIDI.framework/ Versions/A/CoreMIDI
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0 thread_create: 0 thread_set_state: 0
Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0
Calls made by all processes on this machine: task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=790.1M resident=0K(0%) swapped_out_or_unallocated=790.1M(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
VIRTUAL REGION
SIZE COUNT (non-coalesced)
======= ======= 256K 2
256K 1 24.2M 512
236K 27 9176K 127
16K 3 1696K 26
REGION TYPE =========== Accelerate framework Activity Tracing
CG image ColorSync CoreAnimation CoreGraphics CoreUI image data Foundation
Kernel Alloc Once
MALLOC 1.6G MALLOC guard page
Rosetta Arena
Rosetta Generic
Rosetta IndirectBranch 1024K Rosetta JIT 128.0M Rosetta Return Stack 240K Rosetta Thread Context 240K
32K 2 8K 1
74 288K 18
4096K 2 1316K 326
1 1
24 24
STACK GUARD 8K Stack 16.1M 11 Stack Guard 56.0M
VM_ALLOCATE
VM_ALLOCATE (reserved)
(unallocated)
__CTF 824
__DATA 34.0M
__DATA_CONST 37.2M __DATA_DIRTY 1598K __FONT_DATA 2352
__LINKEDIT 137.3M
__OBJC_RO 71.8M
__OBJC_RW 2197K
__TEXT 652.8M
dyld private memory 260K
mapped file 209.9M
shared memory 824K
=========== ======= ======= TOTAL 3.0G 3029
TOTAL, minus reserved VM space 3.0G 3029
----------- Full Report -----------
2
9
63
1 557
356 202
1 10 1
2 577
2 44
19
5352K
4K 1
reserved VM address space
{"app_name":"TheLightingController","timestamp":"2024-07-26 11:32:23.00 -0700","app_version":"","slice_uuid":"81e0d438-83c0-389d-9fd7-94215e83b8c3","build_ version":"0.1","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309"," os_version":"macOS 14.5 (23F79)","roots_installed":0,"incident_id":"50997514- D498-4515-9018-770BE76347F5","name":"TheLightingController"}
"uptime" : 66000,
"procRole" : "Background", "version" : 2,
"userID" : 503, "deployVersion" : 210, "modelCode" : "Macmini9,1", "coalitionID" : 2740, "osVersion" : {
"train" : "macOS 14.5", "build" : "23F79", "releaseType" : "User"
"captureTime" : "2024-07-26 11:32:23.1379 -0700",
"codeSigningMonitor" : 1,
"incident" : "50997514-D498-4515-9018-770BE76347F5",
"pid" : 2616,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2024-07-26 07:10:37.8646 -0700",
"procStartAbsTime" : 1216754234384,
"procExitAbsTime" : 1593689942871,
"procName" : "TheLightingController",
"procPath" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/
"bundleInfo" : {"CFBundleVersion":"0.1"},
"parentProc" : "launchd",
"parentPid" : 1,
"crashReporterKey" : "0BF3B397-640F-88D5-1AAD-E585C58AA214", "codeSigningID" : "TheLightingController",
"codeSigningTeamID" : "Y37848Q249",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4343558144\n
REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT
102e57000-10311b000 [ 2832K] r-x\/r-x SM=COW \/Volumes\/*\/ TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes": [1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_AD DRESS at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2616},
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4343558144\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system": {"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted": {"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 11,
"threads" : [{"id":1518138,"threadState":{"flavor":"x86_THREAD_STATE","rbp": {"value":1000000},"r12":{"value":13058103616},"rosetta":{"tmp2": {"value":140703355055676},"tmp1":{"value":140705773988428},"tmp0": {"value":18446744073709551615}},"rbx":{"value":1},"r8": {"value":3943948209750784},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":
{"value":3187580128427311971},"r9":{"value":1000000},"r13":{"value":0},"rflags": {"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":918272},"rcx": {"value":0},"r14":{"value":13058066560},"rsi": {"value":140643486107232}},"queue":"com.apple.main-thread","frames": [{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":7 },{"imageOffset":64097,"symbol":"nanosleep","symbolLocation":199,"imageIndex":8}, {"imageOffset":1895527,"imageIndex":5},{"imageOffset":381423,"imageIndex":5}, {"imageOffset":731797,"imageIndex":5},{"imageOffset":206580,"imageIndex":5}, {"imageOffset":119648,"imageIndex":5}, {"imageOffset":25446,"symbol":"start","symbolLocation":1942,"imageIndex":0}]}, {"id":1518187,"name":"com.apple.rosetta.exceptionserver","threadState": {"flavor":"x86_THREAD_STATE","rbp":{"value":9908489551872},"r12": {"value":4350593436},"rosetta":{"tmp2":{"value":0},"tmp1": {"value":4462471060343},"tmp0":{"value":10337986281472}},"rbx": {"value":4462471060343},"r8":{"value":2307},"r15":{"value":4831842304},"r10": {"value":15586436317184},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":0},"r13": {"value":4352707456},"rflags":{"value":582},"rax":{"value":268451845},"rsp": {"value":10337986281472},"r11":{"value":0},"rcx":{"value":17314086914},"r14": {"value":0},"rsi":{"value":2616}},"frames":[{"imageOffset":17556,"imageIndex":3}]}, {"id":1518212,"frames":[{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":7 },{"imageOffset":64097,"symbol":"nanosleep","symbolLocation":199,"imageIndex":8}, {"imageOffset":1895527,"imageIndex":5},{"imageOffset":123898,"imageIndex":5}, {"imageOffset":1739344,"imageIndex":5}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp":{"value":50000000},"r12": {"value":0},"rosetta":{"tmp2":{"value":140703355055676},"tmp1": {"value":140705773988428},"tmp0":{"value":18446744073709551615}},"rbx": {"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi": {"value":3178538865786946403},"r9":{"value":50000000},"r13":{"value":0},"rflags": {"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":105553162144784},"rcx": {"value":0},"r14":{"value":13060828896},"rsi":{"value":13060828976}}}, {"id":1518222,"name":"com.apple.NSEventThread","threadState": {"flavor":"x86_THREAD_STATE","rbp":{"value":261696652312576},"r12": {"value":4294967295},"rosetta":{"tmp2":{"value":140703355104392},"tmp1": {"value":140705773988712},"tmp0":{"value":18446744073709551615}},"rbx": {"value":261696652312576},"r8":{"value":0},"r15":{"value":261696652312576},"r10": {"value":261696652312576},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9": {"value":261696652312576},"r13":{"value":21592279046},"rflags":{"value":643},"rax": {"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx": {"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames": [{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":7}, {"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageInde x":7},
{"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageInd ex":7},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":7}, {"imageOffset":510217,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":14 3,"imageIndex":10}, {"imageOffset":504700,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageInd ex":10}, {"imageOffset":501849,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imag eIndex":10}, {"imageOffset":1690556,"symbol":"_NSEventThread","symbolLocation":122,"imageInde x":11}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]}, {"id":1518227,"frames":[{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":7 },{"imageOffset":64097,"symbol":"nanosleep","symbolLocation":199,"imageIndex":8}, {"imageOffset":1895527,"imageIndex":5},{"imageOffset":344981,"imageIndex":5}, {"imageOffset":1739344,"imageIndex":5}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp":{"value":1000000},"r12": {"value":0},"rosetta":{"tmp2":{"value":140703355055676},"tmp1": {"value":140705773988428},"tmp0":{"value":18446744073709551615}},"rbx": {"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi": {"value":3184208398711325539},"r9":{"value":1000000},"r13":{"value":0},"rflags": {"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14": {"value":13062425888},"rsi":{"value":0}}},{"id":1518228,"frames": [{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":16250,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7} , {"imageOffset":26355,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageInd ex":9},{"imageOffset":1738555,"imageIndex":5},{"imageOffset":356569,"imageIndex":5}, {"imageOffset":345450,"imageIndex":5},{"imageOffset":1739344,"imageIndex":5}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta": {"tmp2":{"value":140703355055984},"tmp1":{"value":140705773988428},"tmp0": {"value":18446744073709551615}},"rbx":{"value":0},"r8": {"value":140703355314621,"symbolLocation":0,"symbol":"_pthread_psynch_cond_clean up"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9": {"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp": {"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13063487488},"rsi": {"value":0}}},{"id":1518229,"frames":[{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":5070,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":7}, {"imageOffset":64648,"symbol":"mach_msg2_internal","symbolLocation":84,"imageInde x":7}, {"imageOffset":34064,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageInd ex":7},{"imageOffset":5821,"symbol":"mach_msg","symbolLocation":19,"imageIndex":7},
{"imageOffset":204370,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":98,"imageIndex":12}, {"imageOffset":268474,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocati on":104,"imageIndex":12}, {"imageOffset":257750,"symbol":"CADeprecated::XThread::RunHelper(void*)","symbolL ocation":10,"imageIndex":12}, {"imageOffset":264451,"symbol":"CADeprecated::CAPThread::Entry(CADeprecated::CA PThread*)","symbolLocation":77,"imageIndex":12}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp":{"value":356254652301312},"r12": {"value":0},"rosetta":{"tmp2":{"value":140703355104392},"tmp1": {"value":140705773988712},"tmp0":{"value":18446744073709551615}},"rbx": {"value":356254652301312},"r8":{"value":0},"r15":{"value":356254652301312},"r10": {"value":356254652301312},"rdx":{"value":0},"rdi":{"value":0},"r9": {"value":356254652301312},"r13":{"value":17179869186},"rflags":{"value":643},"rax": {"value":268451845},"rsp":{"value":0},"r11":{"value":100},"rcx": {"value":17179869186},"r14":{"value":100},"rsi":{"value":100}}},{"id":1518245,"frames": [{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":7750,"symbol":"__open_nocancel","symbolLocation":10,"imageIndex":7}, {"imageOffset":71768,"symbol":"open$NOCANCEL","symbolLocation":224,"imageIndex" :7},{"imageOffset":74307,"symbol":"fopen","symbolLocation":71,"imageIndex":8}, {"imageOffset":2000556,"imageIndex":5},{"imageOffset":2000912,"imageIndex":5}, {"imageOffset":341369,"imageIndex":5},{"imageOffset":263089,"imageIndex":5}, {"imageOffset":1023412,"imageIndex":5},{"imageOffset":1739344,"imageIndex":5}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp": {"value":18446744069414584320},"r12":{"value":0},"rosetta":{"tmp2": {"value":140703355111512},"tmp1":{"value":140705773988428},"tmp0": {"value":18446744073709551615}},"rbx": {"value":140704483363848,"symbolLocation":600,"symbol":"usual_extra"},"r8": {"value":13066143072},"r15":{"value":105553130719104},"r10": {"value":140704483363848,"symbolLocation":600,"symbol":"usual_extra"},"rdx": {"value":0},"rdi":{"value":105553119314984},"r9": {"value":18446744069414584320},"r13":{"value":2},"rflags":{"value":642},"rax": {"value":4},"rsp":{"value":1518245},"r11":{"value":6},"rcx":{"value":0},"r14": {"value":2},"rsi":{"value":7}}},{"id":1518660,"frames": [{"imageOffset":141644,"imageIndex":3}],"threadState": {"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12": {"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx": {"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx": {"value":13068898304},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags": {"value":531},"rax":{"value":13069434880},"rsp":{"value":409604},"r11":{"value":0},"rcx": {"value":85011},"r14":{"value":0},"rsi":{"value":0}}},{"id":1518661,"frames": [{"imageOffset":141644,"imageIndex":3}],"threadState": {"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":
{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx": {"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx": {"value":13069455360},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags": {"value":531},"rax":{"value":13069991936},"rsp":{"value":409604},"r11":{"value":0},"rcx": {"value":69703},"r14":{"value":0},"rsi":{"value":0}}},{"id":2323737,"frames": [{"imageOffset":140705773988472,"imageIndex":6}, {"imageOffset":15942,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":7 },{"imageOffset":64097,"symbol":"nanosleep","symbolLocation":199,"imageIndex":8}, {"imageOffset":1895527,"imageIndex":5},{"imageOffset":1023501,"imageIndex":5}, {"imageOffset":1739344,"imageIndex":5}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"thre adState":{"flavor":"x86_THREAD_STATE","rbp":{"value":1000000},"r12": {"value":0},"rosetta":{"tmp2":{"value":140703355055676},"tmp1": {"value":140705773988428},"tmp0":{"value":18446744073709551615}},"rbx": {"value":1},"r8":{"value":0},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi": {"value":3186524459825693539},"r9":{"value":1000000},"r13":{"value":0},"rflags": {"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14": {"value":13065084496},"rsi":{"value":13065084512}}}, {"triggered":true,"id":2323741,"threadState":{"r13":{"value":0},"rflags":{"value":514},"rax": {"value":0},"rosetta":{"tmp2":{"value":4350593436},"tmp1":{"value":4345297488},"tmp0": {"value":0}},"r14":{"value":105553157922976},"rsi":{"value":140642962433776},"r8": {"value":18446744073709551615},"rdx":{"value":0},"r10":{"value":16},"r9": {"value":66},"r15":{"value":4347411624},"rbx":{"value":105553169874456},"r11": {"value":105553162341872},"rip":{"value":0},"rbp":{"value":13067206576},"rsp": {"value":13067206536},"r12":{"value":0},"rcx": {"value":13067206656},"flavor":"x86_THREAD_STATE","rdi":{"value":0}},"frames": [{"imageOffset":0,"imageIndex":6}, {"imageOffset":24971,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9}, {"imageOffset":6883,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]}],
"usedImages" : [ {
"source" : "P",
"arch" : "x86_64",
"base" : 8646488064,
"size" : 593920,
"uuid" : "baa6f02e-dff3-3562-8c99-ea2820c91ad9", "path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 4495130624,
"size" : 180224,
"uuid" : "551047f4-3f3d-3722-b296-aed4f64c1b3e", "path" : "\/Volumes\/*\/efk_hardware.dylib",
"name" : "efk_hardware.dylib" },
"source" : "P",
"arch" : "x86_64",
"base" : 4494766080,
"size" : 53248,
"uuid" : "a994ca6d-8d6a-312f-a7d9-a1a01cb10e70", "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64",
"base" : 140703126233088,
"size" : 196608,
"uuid" : "b091dec9-37ac-322a-bd9d-fc5dc22b0082", "path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"source" : "P",
"arch" : "arm64",
"base" : 4486946816,
"size" : 344064,
"uuid" : "8a85f070-3849-3b55-adde-143cc5902f92", "path" : "\/Library\/Apple\/*\/libRosettaRuntime", "name" : "libRosettaRuntime"
"source" : "P",
"arch" : "x86_64",
"base" : 4343558144,
"size" : 2899968,
"uuid" : "81e0d438-83c0-389d-9fd7-94215e83b8c3",
"path" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/
"name" : "TheLightingController", "CFBundleVersion" : "0.1"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703355039744,
"size" : 241656,
"uuid" : "13597eeb-2ea0-3d48-8be1-dfc4872a784b", "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", "name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703353888768,
"size" : 557048,
"uuid" : "93fb3816-608b-33af-83d2-209b4bd673ad", "path" : "\/usr\/lib\/system\/libsystem_c.dylib", "name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703355281408,
"size" : 49144,
"uuid" : "25b2f3eb-07b4-3cb9-9457-2c26210c27c8", "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", "name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703355703296,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4825085,
"uuid" : "a32f4005-d666-32c2-8e52-f67fc64616e0",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/
CoreFoundation",
"name" : "CoreFoundation", "CFBundleVersion" : "2503.1"
"source" : "P",
"arch" : "x86_64",
"base" : 140703412383744, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.AppKit",
"size" : 21164019,
"uuid" : "33ecd3dc-c895-35e2-a1fd-c1761b155964",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", "name" : "AppKit",
"CFBundleVersion" : "2487.60.105"
"source" : "P",
"arch" : "x86_64",
"base" : 140703815196672,
"CFBundleShortVersionString" : "2.0",
"CFBundleIdentifier" : "com.apple.audio.midi.CoreMIDI",
"size" : 573430,
"uuid" : "cfc251d3-dbe1-3faa-af28-a2c43a47e0e3",
"path" : "\/System\/Library\/Frameworks\/CoreMIDI.framework\/Versions\/A\/
CoreMIDI",
"name" : "CoreMIDI", "CFBundleVersion" : "88"
"sharedCache" : {
"base" : 140703350865920,
"size" : 25769803776,
"uuid" : "6f51a82c-c96c-3bc8-82ca-9c109185bd3c"
"vmSummary" : "ReadOnly portion of Libraries: Total=790.1M resident=0K(0%)
swapped_out_or_unallocated=790.1M(100%)\nWritable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced)
\n===========
256K 2 \nActivity Tracing
512 \nColorSync
127 \nCoreGraphics
26 \nFoundation 32K
\nMALLOC 1.6G 74 \nMALLOC guard page
18 \nRosetta Arena
326 \nRosetta IndirectBranch 1 \nRosetta Return Stack
24 \nSTACK GUARD \nStack Guard \nVM_ALLOCATE (reserved) (unallocated)\n__CTF
557 \n__DATA_CONST
4096K 2 \nRosetta Generic 1024K 1 \nRosetta JIT
240K 24 \nRosetta Thread Context
8K 2 \nStack 16.1M 11
1598K 137.3M 2197K 260K 824K 3.0G
652.8M 577 \ndyld private memory 209.9M 44 \nshared memory
======= ======= \nAccelerate framework 256K 1 \nCG image
56.0M
202 \n__FONT_DATA 10 \n__OBJC_RO
2 \n__TEXT
2 \nmapped file
19 \n===========
3029 \nTOTAL, minus reserved VM space 3.0G 3029 \n",
24.2M 9176K
1696K 8K 1
288K 1316K
9 \nVM_ALLOCATE 5352K 63
236K 27 \nCoreAnimation 16K 3 \nCoreUI image data
4K 824
37.2M
1 reserved VM address space
2 \nKernel Alloc Once
1 \n__DATA
356 \n__DATA_DIRTY
2352 1 \n__LINKEDIT 71.8M 1 \n__OBJC_RW
34.0M
======= ======= \nTOTAL
128.0M 240K
"legacyInfo" : { "threadTriggered" : {
"logWritingSignature" : "59b41aceceecfdfd7911952921714aa2eae15c9e", "trialInfo" : {
"rollouts" : [
"rolloutId" : "5ffde50ce2aacd000d47a95f", "factorPackIds" : {
"deploymentId" : 240000419 },
"rolloutId" : "64b21a7351cbb02ce3442e4e", "factorPackIds" : {
"REMINDERS_GROCERY" : "659475af5595a45664475f23" },
"deploymentId" : 240000037 }
"experiments" : [
"treatmentId" : "c47ab4cc-c9c3-4b5d-a87c-e2433ce02597", "experimentId" : "6639bc6ba73d460582162323", "deploymentId" : 400000006
"treatmentId" : "45f4e2a5-551b-4bc2-a2dc-19c244dda8f8", "experimentId" : "6643969b3099cf28e049862f", "deploymentId" : 400000007
Model: Macmini9,1, BootROM 10151.121.1, proc 8:4:4 processors, 16 GB, SMC Graphics: Apple M1, Apple M1, Built-In
Display: Sceptre F24, 1920 x 1080 (1080p FHD - Full High Definition), Main, MirrorOff, Online
Display: Sceptre F24, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online Memory Module: LPDDR4, Micron
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Jan 13 2024 03:06:59 version 18.20.440.9.7.8.167 FWID 01-7be24857
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0 USB Device: USB31Bus
USB Device: USB-C dongle
USB Device: USB30Bus
USB Device: D1024
Thunderbolt Bus: Mac mini, Apple Inc. Thunderbolt Bus: Mac mini, Apple Inc.
Just FYI, V9.3.17 for MacOS is online ; compiled with the most recent development tools: https://forum.thelightingcontroller.com ... php?t=8068
Not sure it will change your problem, but it cost nothing to try it.
Return to “Mac OS”
