Crashing on Sonoma
lockhap
Crashing on Sonoma
Post by lockhap »
Over the last few weeks, I have noticed the software crashing more often, once a week, while running a show. There is no activity other than the lights on when the software crashes. I move to Sonoma about 6 weeks ago, and it seemed pretty stable. Recently I updated to the latest version and then I noticed an increase in the number of times that the application crashed.
Running Mac mini M1 on Sonoma using ShowXPress 9.3.8 with 1 universe
Re: Crashing on Sonoma
You updated to the latest version of macOS or TheLightingController ?
Please send us the crash reports and, if possible, send us your light show and tell us how to reproduce the crash.
lockhap
Post by lockhap »
I updated both as stated in my original post. I have found the issue to be the listener. The only time it crashes is when I have the Network External App enabled. I have tried updating the IP Address and it causes an error as soon as it boots up. I have had to disable this option to avoid the crashing, but use this to control the app remotely.
Please try with the latest fix file (9.3.12), things have been fixed regarding "External App" connection.
https://forum.thelightingcontroller.com ... =85&t=3438
The fix file contains only now the DMG file (V9.3.12) for MacOS.
lockhap
Post by lockhap »
I installed the fix attached and activate the network listener. I connected to ShowXPress form Companion and let the software run overnight. I logged into the computer this morning to find the software had crashed again. Attached is the Crash Report.
Translated Report (Full Report Below)
Process: TheLightingController [2321]
Path: /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 503
Date/Time: 2024-02-13 06:47:00.7314 -0800
OS Version: macOS 14.2.1 (23C71)
Report Version: 12
Anonymous UUID: 0BF3B397-640F-88D5-1AAD-E585C58AA214
Time Awake Since Boot: 140000 seconds
System Integrity Protection: enabled
Crashed Thread: 11
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Regarding Companion, please read this post https://forum.thelightingcontroller.com ... 933#p32193
lockhap
Post by lockhap »
So the last crash was only with the "External App" enabled(Checked). I have disabled the Companion connection and when showXpress crashed, the Companion computer was not even on. This seems to still be an issue with the "External App' option checked. The crash report that I attached was from opening showXpress with nothing connecting to it and leaving the computer on for hours.
Thank you for this information.
We will try to reproduce and look at what could cause this.
In the next fix file (9.3.14), we updated some code and added a "Do not use WebSocket" option in the network preferences.
Please try with this file (when available) and with the "Do not use WebSocket" option checked.
Return to “Mac OS”
