D512 unit not outputting to lights [fixed]
usb to dmx (2009 - 2019)
JohnRichards
Re: D512 unit not outputting to lights (windows 10, showXpre
Post by JohnRichards »
If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
1 - Driver not the correct driver
2 - Incompatible usb 3 port.
I would suggest you try and install on an old machine with Win XP
John
ray-j-17
Post by ray-j-17 »
support wrote:And what about #5 ?
Yes, I have done that... sorry for my delayed reply... :3
ray-j-17
Post by ray-j-17 »
JohnRichards wrote:If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
John
I have tried it on an old windows so machine, it still didn't work. Ill see if I can find an so computer somewhere if needs be.
niesten
Post by niesten »
Here exactly the same :-(
Sweetlight 512 box, always worked fine. A few weeks ago updated to windows 10 and the laptop doesn't recognize the box (0 universes found) and the box shows the standalone led.
DMX bargraphs are showing signal, only 1 light connected (2 diff dmx cables checked, 3 different usb cables, still nothing). Light works with another DMX controller so light is working...
Looks like there is some driver issue for the sweetlight box in windows 10 :-(
Anyone who has Sweetlight box working on windows 10 ?!?
BartKrap
Post by BartKrap »
niesten wrote:Here exactly the same :-(
Working just fine over here (V8.1.10)
ray-j-17
Post by ray-j-17 »
I know it is a long time since I posted this, but I figured I best explain how I sorted the issue (which I did a long time ago. maybe in a galaxy far away, I cannot remember).
this unit does definitely need a USB hub to work. I actually ended up going through 3 or 4 before I was happy with one (and later found out that one of the ones I bought is synonymous with killing apple macs). after I had a good one running, my unit has been working absolutely fine. shame that there were no notes of it needing one anywhere where I bought it. :3
Thank you for the feedback.
ray-j-17
Post by ray-j-17 »
No probs... All I can say is sorry for the delay. Must be a good year by now. :-P
Return to “D512”
