Shehds - 275W Beam Moving Head
Posted: 05 January 2024, 18:55
by CrocoRDM
Bonjour je n'arrive pas a créer un fichier propre pour mes nouvelles lyres beam 10r de chez shehds
https://drive.google.com/file/d/1fUPsgS ... sp=sharing
Est il possible que vous éditiez un fichier avec le peu d'infos dispo sur le manuel?
Sinon j'ai répertorié chaque couleur, chaque gobo et pas mal d'infos manquantes a la main
Re: Lyre beam 10r shehds
Posted: 07 January 2024, 16:24
On a publié une librairie avec les infos disponibles.
Pour faire mieux, il faudrait effectivement que vous donniez plus d'infos.
Re: Shehds - 275W Beam Moving Head
Posted: 21 January 2024, 15:05
by CrocoRDM
ok
J'ai testé tous les canaux incomplets et j'ai ça comme infos en plus :
ViewType = VIEW_TYPE_HEAD
ViewPower = VIEW_POWER_LAMP250W
ViewAnglePan = 540
ViewAngleTilt = 270
ViewAngleBeam = 15
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
3DViewShape = default
2DViewImage = Showtec/Moving Heads/indigo_250.png
Channel = pan
Channel = tilt
Channel = upan
Channel = utilt
Channel = pantilt_speed
Channel = rainbow_color
Channel = strobe_effect
closed,0,0 open,1,50 strobe,51,240 open,241,255
Channel = dimmer
Channel = color
full_white,0,3 dark_yellow,4,7 red,8,11 2000K,12,15 light_yellow,16,19 macro_1,20,23 violet,24,27 macro_2,28,31 blue,32,35 macro_3,36,39 green,40,43 macro_4,44,47 orange,48,51 macro_5,52,55 cyan,56,59 pastel_cerulean_blue,60,63 pink,64,67 macro_6,68,71 yellow,72,75 pastel_yellow_green,76,79 light_green,80,83 pastel_grey_pearl,84,87 cold_white,88,91 light_yellow,92,95 light_red,96,99 macro_7,100,103 dark_blue,104,107 5500-3400K,108,111 natural_white,112,115 macro_8,116,127 right_rotate,128,191 left_rotate,192,255
Channel = color effect
stop,0,127 linear_colors,128,255
Channel = gobo
Miscellaneous/open,0,8 Miscellaneous/gobo1,9,17 Miscellaneous/gobo2,18,26 Miscellaneous/gobo3,27,35 Miscellaneous/gobo4,36,44 Miscellaneous/gobo5,45,53 Miscellaneous/gobo6,54,62 Miscellaneous/gobo7,63,71 Miscellaneous/gobo8,72,80 Miscellaneous/gobo9,81,89 Miscellaneous/gobo10,90,98 Miscellaneous/gobo11,99,107 Miscellaneous/shake_gobo12,108,116 Miscellaneous/gobo13,117,127 Miscellaneous/right_rotate,128,191 Miscellaneous/left_rotate,192,255
Channel = gobo_shake
shake,0,0 speed_control,1,191 stop,192,255
Channel = focus
Channel = prism
Channel = prism_rotate
Channel = reset
lamp_off,100,105 lamp_on,200,205 reset,206,206
Posted: 22 January 2024, 08:13
Merci
On a mis le fichier à jour dans notre système.
