How to destinguish between 2 D1024s in the DMX tab
Posted: 01 September 2023, 06:19
by jeffreydean1999
I have 2 1024s and if I look in the DMX tab for available devices to assign to a universe I will see both D1024s in the drop down menu. I will also see a numeric value beside each of them but that numeric value has been alternating every-time I boot up the MacBook Pro and open ShowXpress. As a result I often open the Lighting controller and have scrambled, reassigned universes. On top of the rotating number assignment for each of the 1024s it also makes no distinction between which of the 2 available universes on each 1024 you are assigning. I originally thought that probably the 1st assigned in the DMX tab would correlate to the 1st dmx output (xlr outlet) on the 1024 box but that has proven to be inconsistent. It would be nice to not have to guess, or go through multiple trial and errors assignments every-time I boot up the light show. What is the solution?
Re: How to destinguish between 2 D1024s in the DMX tab
Posted: 01 September 2023, 10:06
Here is an example with one interface D1024
And here is an example with two interfaces D1024
"1 (D1024)" means the first interface
The first line from the top is always the first DMX output of the interface.
The second line from the top is always the second DMX output of the interface.
"2 (D1024)" means the second interface
That said, please note that using the option "
Change defaut DMX universes mapping" is not mandatory. You can leave it unchecked, let the computer decide the interfaces order and plug your DMX lines according to the default DMX lines setup.
Posted: 01 July 2025, 20:38
by muscanto
Does Each interface have a unique addres or number that could be reference by the software when showing mapping? I struggle with this two now that I'm running more than one interface.
I see a UPC, a S/N and another barcode on my D1024. Can the software read any of this info? If not, can you add an "identity dongle" feature where we can make the LED blink a certain pattern? Either USB or Power?
Posted: 02 July 2025, 07:02
The software does not see any difference between the two DMX interfaces.
Again, the option "Change defaut DMX universes mapping" is only for specific use. When not needed we suggest to not use it and let the computer decide the interfaces order and plug your DMX lines according to the default DMX lines setup.
