External Control changes in version 9.3.4 BETA
Posted: 29 November 2022, 21:38
According to https://thelightingcontroller.com/viewt ... 433#p30553, there is a:
As you can see from https://thelightingcontroller.com/viewt ... =78&t=6614, I use the TCP endpoint documented in http://download.thelightingcontroller.c ... otocol.pdf to control TLC from Companion, making it useable from a StreamDeck. The module has quite a few active users and so I'm just checking that the latest beta doesn't make any changes to the API, or, if it does, is there an updated document?New method to manage external messages.
