Wireless Transmitter Not Sending Signal
post here other topics
KRkrKR
Post by KRkrKR »
Hello All!
I am a brand newbian to lighting and am setting up showxpress for the first time.
I'm trying to patch a single Slimpar 56, with a Donner wireless transmitter and receiver.
I followed setup instructions for patching in a fixture, made sure that I was selecting the correct device, correct channel mode, and correct DMX address.
After patching in I made sure that I clicked the DMX send button in the Steps tab, it is green and sending,
However, I see no response from my Slimpar, and the lights are not blinking on my (fully charged) wireless transmitter or receiver.
I'm running on a 2016 MacBook Pro, Monterey. Power indicator is on and PC link light is blinking on my Showxpress book.
What am I missing?
KRkrKR
Re: Wireless Transmitter Not Sending Signal
Post by KRkrKR »
Also- I made sure that, when charging, transmitter and receiver were set to the same frequency/color. Neither one is lighting up when paired when plugged into their respective homes
Robin_D
Post by Robin_D »
Find a cable and connect the dmx output directly to the PAR. If that doesn't work then you have a problem with either the DMX output device, or the PAR. You have four devices in the chain, it could be any of them causing the issue, or a patching issue in ShowXpress. Best get as few links in the chain to get it working, then worry about the wireless link.
Just because the screen shows DMX being sent, doesn't mean it actually is. All its telling you is that DMX output is turned on in the software.
Try another luminaries if possible.
Good luck.
Please confirm that all these points are ok : https://forum.thelightingcontroller.com ... f=15&t=613
KRkrKR
Post by KRkrKR »
Thank you all!
Issue is resolved as a problem with the transmitter and receiver.
Good news !
Thank you for the feedback.
Return to “Other”
