How to link buttons to "Master Speed" ? [fixed]
Posted: 30 June 2021, 16:34
by CPSL
Hello again!
I used ShowXpress' (ver. 9.2.23 64 bit on MacBook Pro) "Lightshow Creator" to create a basic palette for color, movement, etc... with my Hybrid 140SR's and LED Par lights. It gave me two main faders; a master "Dimmer" and a master "Speed". The dimmer works flawlessly. I can't see that the master speed control does anything. Question - What does the "speed" actually control?
Note: Changing the "BPM" doesn't seem to change anything either. Thoughts?
Again, Thank you for your last response. 100% accurate and 100% appreciated!
Cheers,
Scot
Re: ShowXpress 9.2 Lightshow Creator "Master Speed"
Posted: 30 June 2021, 20:18
by thorehl
In Live > Buttons you can "right click (Windows)" a button and select Speed properties.
Select, there you will see Master speed dropdown menu that will allow you to select what buttons (scenes) Master Speed fader will affect
Posted: 01 July 2021, 00:50
by CPSL
Figured it out... Speed between step and must be enabled in "speed properties" of each button.
Have a great night.
Re: How to link buttons to "Master Speed" ? [fixed]
Posted: 07 July 2021, 19:21
by thorehl
Yeah. I always default time between steps to 1 sec. Easier to work with on the fly.
Have fun programming
