XFMT - Par 18 x 15W RGBWA LED
Posted: 11 May 2020, 17:32
by PTJones
XFMT 5 In 1 DJ Par Lights 18 x 15W RGBWA LED Stage Party Show Lighting PAR64 DMX Sound-Active
Using 9 Channel DMX
I can not find the manual online for this light. I purchased through Amazon and that is where I got the following information. Thanks for your help.
SPECIFICATION:
Input Voltage AC90-240V 50-60Hz
Light Source 18PCS*15W 5IN1 RGBWY LEDs
Power Consumption 300W
Lamp Lifetime 100,000 hours
Lense degrees 25°
Color Mixing system 5IN1 RGBWY unlimited color mixing system
Control Mode DMX-512, Master/Slave, Sound, Auto
Operation Panel LED Digital Display
DMX Channels 9CH
Signal Input 3-core XLR input
Signal Output 3-core XLR output
Dimmer 0 ~ 100% linearly adjustable
Strobe 0-20 t/s
Maximum ambient temperature 40°
Maximum lamp temperature 60°
Housing Material Die-cast aluminum housing
Housing Color Black
Function Color Changing, Color Fade, Strobe
Net Weight 9 KG
Gross Weight 10 KG
Packing Size L410×W320×H370mm
DMX Channel Information(9CH):
Channel Channel Value Function description
CH1 0-255 Dimmer
CH2 0-255 Strobe from slow to fast
CH3 0-50 Open CH1-CH5
51-100 Color selection procedures
101-150 Gradual program
151-200 Clock change program
201-250 Hopping program
251-255 Sound open
CH4 0-255 Speed from slow to fast
CH5 0 Red off
1-255 From dark to light gradient
CH6 0 Green close
CH7 0 Blue close
CH8 0 White close
CH9 0 Yellow close
Re: XFMT 5 In 1 DJ Par Lights 18 x 15W RGBWA LED
Posted: 14 May 2020, 18:17
Done.
