Chauvet - Scorpion Dual RGB
Posted: 28 January 2020, 00:40
by onfiremusik
Hello. I hope I have this posted in the correct location. I already called and voiced the showxpress profile issue but figured I would post it here in hopes to get it fixed asap.
The profile that Showxpress comes with is just "Scorpion Dual" and I downloaded the "Scorpion Dual RGB" profile from chauvet.com.
I setup my laser at the club but used the "Scorpion Dual" profile by accident. It looked a bit odd but it worked. I want to use the correct profile now but I noticed some issues with it as compared to the standard Scorpion Dual. "Scorpion Dual RGB" points to the picture but the actual picture is not found and it defaults to a mirror scanner. Easy fix. I just pointed the file to the standard scorpion. The line "ViewType = VIEW_TYPE_MIRROR" is listed but that should not be. Also comparing the 2 files there is an extra line in the Scorpion Dual Profile that says "3DViewShape =". Not listed in the RGB profile. So What I added/changed in the RGB profile was this: "ViewType = VIEW_TYPE_NOTHING", "3DViewShape =", "2DViewImage = Chauvet/DJ/Scorpion Dual.png". I have not used it yet to be honest so I am not sure if the DMX channels are correct. Is there any way that you can take a look at the "Scorpion Dual RGB" profile for Showxpress and make sure that file is correct to match all the DMX settings as well? I will not be able to test it for about 1 week. I will fall back to the "Scorpion Dual" profile if I must just to get through my show but I want to make sure the channels are set accordingly as I have no idea on how those should look.
Thank You
Re: Chauvet Scorpion Dual RGB
Posted: 29 January 2020, 23:04
by SeekLighting
Hey mate,
As per forum rules please post a link to the manual for the fixture you'd like the programmers to look at :)
https://forum.thelightingcontroller.com ... f=3&t=2453
Regards,
Tim H
Posted: 31 January 2020, 10:38
Posted: 03 February 2020, 15:48
Done.
