Type in values for Points in Generator [done]
Posted: 23 July 2019, 19:55
by DeeStage
It would be nice if we could type in exact values for added Points in the effect generator.
move effects:
Type right click on a ponit to enter a small menu where you can type in the Pan/Tilt value.
In "Move/Size shape" Mode: right click to enter a value for the Center Point of the Movement.
other effects:
right click on a point to set the exact channel value and the time value by percent.
for instance:
Point 1 in a Dimmer effect:
Channel value: 255
Time Value: 25
This will set the Dimmer to 100% at 1/4 of the total project time.
I hope you understand my request and you see how important this feature is.
Re: Type in values for Points in Generator
Posted: 25 July 2019, 10:48
Noted to do at least that: "display X/Y values in real time when positionning the point".
Re: Type in values for Points in Generator [done]
Posted: 04 September 2019, 16:18
"Popup menu to enter pan/tilt values" is done in the fix file.
https://forum.thelightingcontroller.com ... f=2&t=6305
