request - Generator and different fixtures
Posted: 07 January 2019, 14:00
Support,
It would be very useful if you could use the generator across different fixtures by selecting different fixture types and linking the desired channels in the generator window when creating a new generator file. For example, having the ability to control the shutter or dimmer of a mixed group of fixtures would be very useful without having to create two or more generator files and then linking them with a macro or using a steps scene and a lot of programming. I can program chase type strobes manually with step scenes but it's very time consuming and it never looks as good as a generator scene. When you open the generator, you would select which channel on each fixture type should be the same and which fixtures you want to include in that generator check box so you can control the dimming/shutter between two different fixtures.
