4Bar with Pixels
buddukes
4Bar with Pixels
Post by buddukes »
I'm using two of the original 15-channel Chauvet 4Bar fixtures. I can set them up as a 4x1 RGB fixture with the first 3 channels shared and disabled and it will cycle thru the colors I select in the menu on the left including turning off is one or more of those colors is black. What I really want to do is have the individual 4Bar lamps retain the color of scene that was active before activating the Pixels scene. I've tried several ways of faking out the system such as creating 4 individual fixtures, treating them as White light fixtures instead of RGB and setting up the other channels as shared channels and manipulating which ones are shared and setting specific values, but no success. I have several individual fixtures that I treat as White light fixtures where just the dimmer is manipulated and they retain the previous scene's colors. I want the 4Bar lamps to match that. Any way to accomplish this? Thanks!!
buddukes
Re: 4Bar with Pixels
Post by buddukes »
Any ideas on how to accomplish this? Thanks!
Return to “Pixels”
