MIDI controlling two live buttons not working [fixed]
Posted: 10 November 2018, 20:14
by charlie.tornquist
Hi, when I upgraded to V9 I lost the ability to trigger two live buttons with one MIDI button. I am running version 9.1.4. In version 8 I would use one MIDI button to trigger two different live scene buttons (on different pages), but that doesn't appear to be possible in the latest V9 software. When I set two or more live buttons to the same MIDI button only one will trigger. Also, when the live buttons are flash buttons, one will work correctly, but the others will turn on and not be able to be controlled with the same button. Is there a work around or is this a bug?
Re: MIDI controlling two live buttons not working
Posted: 10 November 2018, 23:16
by BartKrap
charlie.tornquist wrote:Hi, when I upgraded to V9 I lost the ability to trigger two live buttons with one MIDI button. I am running version 9.1.4. In version 8 I would use one MIDI button to trigger two different live scene buttons (on different pages), but that doesn't appear to be possible in the latest V9 software. When I set two or more live buttons to the same MIDI button only one will trigger. Also, when the live buttons are flash buttons, one will work correctly, but the others will turn on and not be able to be controlled with the same button. Is there a work around or is this a bug?
That should work. But you are meant to use the macro funcion for this.
Posted: 11 November 2018, 16:25
by Niffo
Confirmed : seems to be a V9 bug, we are going to take a look at this
Posted: 12 November 2018, 22:52
Fixed in the new fix file of today.
