Not able to change/add buttons to pages
Djmultitool
Post by Djmultitool »
*****UPDATE: 9-21-2018*****
was able to crazily click all over the field and get the drop-down-field to show up.... seems that there is a bug in the selection size?????
Im using Windows XP OS installed on a All-in-one Touchscreen computer.
running the latest version of show express... I can add buttons but can not edit the amount of buttons boards..
I click the 3 lines left corner
select: button settings
select Button Boards
Highlight #1: field turns blue but will not allow me to change value...stuck at 1 tab type [CAN NOT EDIT this]
Re: NOT able to change/add buttons to pages
To change the number of boards, click a second time in the blue section in the column "Boards", and you will see a popup menu to select the number.
To add a new tab/window click on the button "Add" below the list.
To add button in a page, close this window, and select "Add Steps/Generator/... scene" in the popup menu of the page.
FYI: https://www.youtube.com/watch?v=AsOWrA8vezk
Djmultitool
Re: Not able to change/add buttons to pages [fixed]
Still A NO GO... I have to create a Button layout on a laptop and then save show on usb and export show then import show into the Venue computer... its a work around but not efficient
