V9 - Samwise309 Feedback
samwise309
Post by samwise309 »
Support,
I've only had a short bit of playtime with V9 so far. User TimH brought up a lot of good initial points about the software;
3D Improvements are great
Multi pan/tilt fixtures and graphics are great
The Create lightshow function is a really neat thing for new users/getting the workflow started
And all the other pros/cons he mentioned are solid points.
The initial bugs I found are:
Certain color and glass gobos create a big frame of color around them - https://youtu.be/qwfndHDZ-E0
In generator 2D, clicking the blank area between fixtures makes a white flash and doesn't de-select your fixtures, like it does in steps. In fact, a bunch of weird things happen between 2D and 3D selection. If you start a new scene and click on a single fixture, it may or may not select the same fixtures from the previous selection. At other times, it deselects the one you click and keeps everything else selected. It's a bit hard to explain, I tried to demonstrate here - https://youtu.be/6tDbqz3QKdU
Here are some feature requests I have:
-The 'randomize' fixture order button for generator. This would save a lot of time when using a big rig and wanting to randomize your effects.
-I would also LOVE to see something implemented down the road where you can click and draw a path around your 2D window, and the fixture order will reflect your mouse path.
-In Edit Steps mode, make channels active and not active between steps. This would make any wipe effect much easier to make.
-For the preset slider function on a step scene; If you assign a button trigger, hitting that button will circulate through the steps instead of turning the current step on and off.
-The fan pan/tilt offset option is pretty neat. I would much rather see that implemented however in STEPS for creating static positions. Would like to see an added dialogue box where you can select the amount of fan for your selected fixtures and that way, making some nice clean positions would be much quicker than individually moving them into a fan position. As an added bonus, attach a "wings" option to the fan dialogue so that you can fan in groups instead of the entire rig.
I will be eagerly testing and adding more feedback as I go!
Re: Samwise309 Feedback
Thank you for this feedback.
3DView - big frame around the gobo
Noted. We will check that.
2DView - white flash
This is normal (no change with V8).
Clicking on nothing with Steps means "see all channels", which makes sense.
With Generator, nothing selected makes no sense. The white flash says "not allowed".
Noted for the other requirements. Some remarks:
Circulate through the steps
This is possible with a normal (no preset mode) button, with "Speed properties" set to "Beat". And "Beat" can be triggered by keyboard, mouse click, midi, ...
Fan pan/tilt offset
You do not have to move individually each fixture. You just have to move the first and the last ones, and the other are auto repositioned.
BartKrap
Post by BartKrap »
Fan pan/tilt offset
You do not have to move individually each fixture. You just have to move the first and the last ones, and the other are auto repositioned.[/quote]
What if I don't want to. Let's say I'm in a very specific situation where my lights aren't perfectly in line but I still want a nice "half moon" shape on the floor. I'd actually like to have the option for auto allign but I'd also like the option to do all of it manually. Maybe that's something for a later version but it would be a nice feature.
Just uncheck the option "Fan pan/tilt offset" and you can move them individually.
BartKrap
Post by BartKrap »
support wrote:Just uncheck the option "Fan pan/tilt offset" and you can move them individually.
Yeah, sorry, just found that out :D
@ Samwise309
Could you please tell us:
1. if same problem with V9 and 3DView forced to the "OpenGL compatibility mode"
2. with V8
We are not able to check that because we do not see this problem here.
