Offset Moving Head Start Position
post here other topics
TheLizardMonkey
Post by TheLizardMonkey »
Hi, First time posting and don't know if this is in the right section but does anyone know how to offset the start position of a moving head in Sweetlight on Windows.
I have recently purchased eight Equinox Fusion Spot Max MKII and the problem is they are mounted at the back of our room on the wall. Therefore I cant go left because that's as far as they go and the only way to go left is to go all the way around 360 degrees but as you can imagine, doing that in the middle of a live light show isn't ideal. That would be fine to do at the beginning of the night but not everytime I want to use them.
My question is, is it possible to offset the start position of the moving head so it sets that 0 then becomes actual slider value 120 so its already gone round when you want to go left
Thank you for any help. Much appreciated
Dawson
Re: Offset Moving Head Start Position
We suggest you to create in Live one button with a one step scene, and leave always this button on.
SeekLighting
Post by SeekLighting »
+1 to support. Create a button that is always on in your live mode that sets the movers to a default position when they are not doing anything else. I usually set this to "centre" (ie. x = 128 and y = 128)
Regards,
Tim H
TheLizardMonkey
Thankyou for all your help. I will try it later
buddukes
Post by buddukes »
I have a very similar question, but slightly different. When I set the reverse pan for my moving heads, either on the units or through the Showxpress software, the home position changes by 90 degrees and therefore I don't get that mirror image I'm looking for (Pan for these fixtures goes up to 630 degrees). Anyway to offset that to compensate for the change in home position so that I do get the mirror image effect I'm trying to achieve? Thanks!
Return to “Other”
