One of the most useful features added to this program is the release all buttons option.
This feature makes setting up macro buttons much easier. I also use it to return to "home" positions in a live busking session.
However, the buttons chosen as exceptions do not hold memory when the program quits.
The exceptions must be re-activated manually each time that show is loaded. This is inconvenient.
A fix for this would be appreciated.
A release all exception would be nice as a window option. Maybe added to the window menu pulldown (right click)
This exception would cover an entire window, not just 1 button at a time.
A solo feature would also be a nice addition to this program.
This feature can be found on larger lighting consoles like Grand MA and Hog 4.
The solo feature would be a fixture group direct control.
It should be able to be pre-programmed by the user as a type of sequential step list with each step being an individual fixture within the group.
Each step can be programmed to activate a fixture so it may be focused (shutter>open Dimmer>Full ect) as if it were a step in a chase.
As a group of fixtures is selected for "solo" the 1st fixture in that group will be lit for focusing, while the others remain dark.
A "go" or advance button will be needed to toggle through the remaining fixtures in that group lighting 1 at a time.
Control of this function would be helpful trough the remote app as focusing is done from the stage.
This would be a very useful feature for someone who uses the same equipment for each event, but in different venues and locations.
Thank you.
"Release all" exception per window Add Solo Button?
SeekLighting
Re: RELEASE ALL exception per window Add Solo Button?
+1 to all these ideas
