Wish list of items for Live
Posted: 02 January 2010, 19:20
Keep in mind I work with live bands and the set list I get may not exist or change from time to time so I have to have a lot of flexibility in the lighting to react to what they choose to play. I also run sound at the same time so this program frees me up a lot to be able to run both.
1.) Rename buttons. I group my live boards by fixture and name the scenes in setup by fixture & function. So, "Red/Blue Par" could be put under the "Par" board and renamed to just "Red/Blue". This way, I can jam more buttons in a board. Depending on the programming, you could make it rather simple to assume the name of the scene as the scene name unless that value was entered in so old shows would not have to be changed. I don't know, maybe a "name=" field in the .ini would do it.
2.) Along the lines of the tap synch button (the drum), could you add a x2, x4, /2, and /4 buttons to double, quatruple, half and quarter the current speed? A lot of songs double or half their tempo and I am pretty on with the drummer as far as my speed. I think I could three taps for new speeds. Having just one button frees me up a lot.
3.) I would like to see a 2nd or 3rd step play/pause button. The Play/Pause button works great but if I had a second one or third one, I could stack my scenes in Live.
4.) Support for 8 boards streched across dual monitors. Sorry, but I think I am not the only one who wants this.
5.) A way to manually edit button sizes. For the most part, the auto size works out fine however; there are some instances, where changing the size of the buttons would be nice for readabiltiy, especially until number 1 is addressed.
Overall, I like the new changes. I have not implemented it in production, yet, but I am close. I am especially happy that you support x64, now. Thank you.
