Showtec - 56 par
lgmiquel
Showtec - 56 par
Post by lgmiquel »
Please help my.
I have a led par type : Showtec 56 par
I can't find a fixure for this.
This is the product:http://www.highlite.nl/index.php/highli ... /showbar_4
I can't find a manual on internet
Thank you :mrgreen:
Miquel
Re: Showtec 56 par
Trickkit
Re: Showtec 56 par
Post by Trickkit »
Je zou de handleiding erbij moeten posten
Dit zou het product moeten zijn:
Alleen er is geen handleiding te vinden dus die zou je het archief moeten halen.
Groete Swen
Trickkit
Re: Showtec 56 par
Post by Trickkit »
Bas_Showtec
Re: Showtec 56 par
Post by Bas_Showtec »
Do you need the fixture file for the Showbar or the fixture file for the LED PAR?
Because the set which you mentioned with the hyperlink is without a LED Par.
Please let me know so I can make the file for you.
Best regards
Bas
lgmiquel
Re: Showtec 56 par
Post by lgmiquel »
Bas_Showtec wrote:Hello,
Best regards
Bas
i will have a fixture for the showbar .
thank you so mutch
Bas_Showtec
Re: Showtec 56 par
for this unit it isn't logical to make a fixture file.
Because you can patch the unit in a lot of different ways:
For example:
Output 1 = channel 001
Output 2 = channel 002
Output 3 = channel 003
Output 4 = channel 004
But it can also be
Output 2 = channel 150
Output 1 = channel 028
Output 2 = channel 400.
So each output is an dimmer on it self.
In the file which I have added to this message is just 1 dimmer fixture.
Best regards
Bas
