3D viewer not showing light
Posted: 20 March 2017, 17:58
by noahg
I'm fairly new to ShowXpress and am learning how to program lights, I have been following the step by step video guide that Chauvet has put on their website for those who are new to the software. Everything has worked so far but i cant seem to get the fixtures to produce light, i have set all the steps for each fixture on a clean slate and still no light in the 3D view. PLEASE HELP, this seems like an easy fix but I can't figure out how to make this work. THANKS!
Re: 3D viewer not showing light
Posted: 20 March 2017, 18:27
by JohnRichards
There can be quite a few things.
1- check if the demo show works
2- have you clicked on the "3D" view button
3- if your interface is "usb cable" disconnect it as it will not work together with 3d
John
Posted: 20 March 2017, 19:08
by noahg
My intelligent lights seem to move in the 3D viewer as i programmed them to do so, but still no light coming from the fixtures.
Posted: 20 March 2017, 19:30
Please post the personality file (in tab Editor => Fixtures, right click over the fixture, select the menu "Edit fixture", and press the button "Export" in the window "Edit fixture").
We will check it.
Posted: 22 March 2017, 23:25
by noahg
Okay thank you, here is the file.
Posted: 23 March 2017, 10:56
With channel dimmer (#7) on, plus one RGB channel (#1 - #3) on, we see the beam, here.
Posted: 30 March 2017, 21:20
by tflanagan2678
I am having the same issue with a fixture profile I made. Can you take a look at it?
Thanks! Sorry for the hijacking!!
Posted: 30 March 2017, 21:23
by tflanagan2678
Also is there a best practices for making a fixture profile?
Posted: 31 March 2017, 08:03
The channel "color" must have color levels.
It is also better to use "shutter" instead of "strobe".
For better understanding, please have a look at the fixtures in the demo_show (viewtopic.php?f=85&t=4556).
Posted: 31 March 2017, 14:33
by tflanagan2678
Excellent!!! Thank you very much for the reply!!!
Have a great weekend!
