button Blackout
Posted: 04 January 2017, 23:18
by ur7ew
Friends, learn how to create one Blackout button, the effect of which is similar to the action Blackout button on the lighting console. Ie when she goes out all pressed and when pressed it works the scene which was before the button was pressed?
Re: button Blackout
Posted: 05 January 2017, 07:48
by beuzz60
Hi, you have to create a scene with just one step and active each dimmer channel you want to "0", see this post: viewtopic.php?f=31&t=383
Use duration and transition type to adjust the " fade out " ;)
