V8.2.4 - stops working with fader on '0' [fixed]
Light_user
Post by Light_user »
When creating a fader button in the live mode, the software crashes when the fader is on '0'.
Light_user
Re: Sweetlight 8.2.4 stops working with fader on '0'
The error log is written with this
Le 21/12/16 - 20:37
Fonction : Engine thread TIMEOUT ! : Live
Le 21/12/16 - 20:37
Le 21/12/16 - 20:37
Le 21/12/16 - 20:37
Please send your lightshow.
We will check that.
We have your lightshow but we are not able to reproduce with v8.2.8.
Please be sure to use v8.2.8 and tell the exact steps to reproduce the crash.
Light_user
Same problem in version 8.2.8.
I'm using the software with my lightshow on Windows 10 (build 10240). Akai APC mini is connected and assigned to the fader button in LIVE view.
When i move the fader down to '0', the software hangs until i force quit the application.
I just tried it without a midi device connected and it's the same problem. The problem occurs when assigning a midi trigger to a live button or live fader. When i remove the midi assignment settings from the live.ini file, the problem doesn't occur anymore.
When there is a midi trigger assigned, and you move the physical fader or the fader on the screen and you move it to value '0' or you press the live button on and off and move the fader up, the program crashes. I can reproduce it everytime, also with a new show in a clean installation of version 8.2.8 or version 8.2.4. Just went back to version 8.1.29 and there i don't have the problem.
cedric
Post by cedric »
Même problème sur la dernière version 8.2.8 chaque fois que je remais le fader en midi à 0 tous le programme plante !
cedric
Post by cedric »
Process: TheLightingController [382]
Path: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [382]
User ID: 501
Date/Time: 2016-12-23 09:50:26.714 +0100
OS Version: Mac OS X 10.12.1 (16B2555)
Report Version: 12
Anonymous UUID: D6DE0A3A-DA86-85B4-8C94-CF0FE06E12FB
Time Awake Since Boot: 1400 seconds
System Integrity Protection: enabled
Crashed Thread: 2
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000016
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x16:
__TEXT 0000000000001000-00000000001eb000 [ 1960K] r-x/rwx SM=COW /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
@cedric : S.V.P, pouvez-vous nous dire exactement comment vous faites pour reproduire ce problème depuis le lancement du logiciel. Quel fader bougez vous ? Dans le logiciel ? Sur un appareil midi ? ...
cedric
Post by cedric »
oui akai apc mini fader dans live
cedric
Post by cedric »
un bouton preset
