[request] - Group Dimmer channels
Posted: 21 September 2016, 18:36
Hi!
I've seen that in new version (8.x.x) there is possibility to group RGB channels as well as Multi Pan-Tilt within generator. I would like to ask you guys for the same for possibility for dimmer channels.
Currently my venue runs few ADJ Sweeper Beam, which contains 8 led, each one with its own dimmer channel. While using generator for making new chases/scenes, I would like to have the possibility to create effects for dimmer in one channel than in 8. In other words - instead of having 8 dimmer channels I would like to group them and run in style like multi-pan-tilt.
Hope you understand what I have in mind.
Cheers!
Cheers!
