comments to Sequential List
Posted: 19 September 2016, 10:51
by MTF Showtechnic
we've installed the new Sweetlight Version with the latest fix 8.1.23. and we're running Windows 10 Enterprise.
First of all: very nice and new helpful features.
Best is Sequential List. I've have seen that it's currently a Beta Version.
I don't know which functions of the Beta working well. I've noticed the following:
Menu- "Move to" is shifted to the wrong position.
For example: Move to 3 will move to position 4, Move to 1 will move to position 2
That's why Position Zero exists but number "0" isn't available. It start's with "1"
Field Trigger: to small to read the german translation. Can you make it a little bit wider?
Drop down "Trigger" and "Loop": Dbl Click isn't really fine. A click on Drop down should open the selection "wait for" and "follow".
First click on Loop selects the scene, second click selects loop fct.
Fade In and Out Time don't work. After the "Duration Time" it will change to next step.
For the rest it's a very good tool cause we're often in theatre's.
Greetings from germany
Re: comments to Sequential List
Posted: 25 September 2016, 17:53
Thank you for this feedback.
We have done something to fix that.
Added in ToDo list.
Drop down "Trigger" and "Loop": Dbl Click isn't really fine. A click on Drop down should open the selection "wait for" and "follow". First click on Loop selects the scene, second click selects loop fct.
Noted. We need some time to think about that.
Noted. We will check that.
Thank you for the ini file (replaced by the more recent one from here viewtopic.php?f=68&t=4620).
Posted: 26 September 2016, 21:13
"Move to" problem fixed in V8.1.25.
viewtopic.php?f=2&t=4593
