Anyone running Mac Sierra? Error on launch
kcjeepman
Post by kcjeepman »
I had to blow away my macbook pro and made the mistake of installing the beta os of sierra. When I installed a fresh copy of ShowXpress, I receive a "library 'efk_hardware' not found !" error even before the splash screen. I downloaded and installed ver 7 and received the same thing. I attached my xpress-512 hardware and received the same thing.
Any input would be helpful. Thanks!
Re: Anyone running Mac Sierra? Error on launch
The software is not tested on this version of Mac OS.
kcjeepman
Post by kcjeepman »
Yeah, I'm sure it's not tested yet. I just didn't know if that error code was indicative of a particular known issue or if anyone was successfully running the beta software. Thxs!
After investigating, it seems Mac OS Sierra has added one more new "security enhancement" that prevents dylib files to execute from a file who is originating from an unsigned disk image (https://eclecticlight.co/2016/06/16/mac ... -updaters/).
As a temporary workaround, it seems you can download the executable file from a zip (http://download.thelightingcontroller.c ... ew/fix.zip) then use it in replacement of the one of the disk image.
Return to “Mac OS”
