Moving lights pan/tilt amplitude problems [fixed]
Posted: 24 May 2016, 20:24
by djcaliente
Hello - I am just starting to use ShowXPress and have imported my 455Z Moving Head fixtures into the editor and 3D View.
I have put my 2 moving heads on 2 square trussing but I am not able to get the beams of light to point download at the crowd level. The picture displayed is the furtherst I get them to point downward with having the X axis at 0 or 255. Any suggestions as to what I am doing wrong?
Re: Mover Panning problems in 3D Mode
Posted: 25 May 2016, 08:04
The personality file might be wrong.
Please, give us the link of the manual of this fixture, and post your lightshow.
We will check (and fix if necessary) the personality file.
viewtopic.php?f=25&t=2176
Posted: 25 May 2016, 14:55
by djcaliente
Hi Support
Thanks for the info. Here is the link to the current manual:
http://www.chauvetdj.com/wp-content/upl ... ev3_WO.pdf
I have posted my current light show here
https://api.wd2go.com/api/1.0/rest/devi ... ea061619fb
Posted: 27 May 2016, 12:07
by djcaliente
From the looks of things does it seem that I am doing something wrong?
Posted: 27 May 2016, 14:13
The link to your lightshow seems to be bad.
Anyway, we checked the personality file in our software's bank, and we found the pan/tilt amplitudes parameters are wrong.
Please do this:
- select the tab "Fixtures"
- double click on the fixture to open the "Edit fixture" window
- in the window "Edit fixture", in section "3DView" enter "540" for "Pan amplitude" and "270" for "Tilt amplitude"
- press "Save" and close the "Edit fixture" window
