auto BPM mode is not working in timeline [fixed]
channel55
Post by channel55 »
I created some timelines with scenes, using the auto BPM mode.
The Problem is that the senes do not react in auto BPM mode after the start of the timeline.
When I start the same scene in live (not included in a timeline), the auto BPM work as expectet.
Regards
Thomas
Re: auto BPM mode is not working in timeline
We made a test with one timeline project having one song and one light scene in auto BPM mode ; we do not see this problem.
Are you using version 6.24 ?
channel55
Post by channel55 »
Hello
yes, I´m using the version 6.24.
I think I found the problem. I used the version 5.XX before. After converting my lightshow to version 6.xx the described problem occured. After opening a scene in v6.24 timeline (just after conversion), the auto BPM mode was still marked, but not working. Reconfirming the selection of the auto BPM mode and saving the setting solved the problem (no problems in the following sessions).
Thanks for your quick response
Thomas
Thank you for this explaination.
We note this in the TODO list.
Return to “TimeLine”
