Waveform not showing [fixed]
JohnRichards
Post by JohnRichards »
For Support or any other user having a similar problem.
I have used Goldwave as my audio editor most of the time for editing wave files, but have recently reverted back to my Wavelab 6.
The waveforms are not displayed if the file has been edited and saved with Wavelab (Pcm 16bit), but if I reload and save with any other software it then shows. Any ideas on this?
John
Re: Waveform not showing
Can you send us a file saved with Wavelab ?
Regars.
JohnRichards
Extract of file to be sent by email.
John
This Wave/PCM format looks a bit weird since his data chunk is very far from the beginning of the file (4Ko of 0 filled bytes).
Anyway, it will be supported for next fix/release.
JohnRichards
Re: Waveform not showing [fixed]
Thanks Niffo and Support.
Did not quite understand the problem, but I think Wavelab is a highly respected audio program.
Do all audio packages save wave files a different wave, or is there a standard that should be adhered to?
John
Return to “Live - TimeLine”
