no "Objects Settings" window [fixed]
lse
Post by lse »
just updated to newest version and when i right click in 3d and selects objects setting i don't get the menu screen.
Re: no object popup screen
What do you see, if you make a second right click ?
lse
Post by lse »
Auto align and exit abject settings
This means the window is open, but for an unknown reason, it is either behind the main 3DView window, or it is open outside of your monitor.
We already saw such problem, with an old software version, when the user change the monitors, like for instance change from two monitors to only one monitor. But, this problem is supposed to be fixed, in current software version.
If you are not able to reach this window, you can do that:
1. make a backup of your lightshow (in case of)
2. open the file "../TheLightingController/LightShows/YourLightshow/3DView/ 3dview.ini", with a notepad
3. delete the lines (when existing)
[Windows]
Frm_ParamScene = ...|...|...|...|...
Frm_ParamDecors = ...|...|...|...|...
Frm_Main = ...|...|...|...|...
Frm_ParamFixtures = ...|...|...|...|...
Frm_Param3D = ...|...|...|...|...
4. save the file and exit
This will reset the positions of all 3DView windows.
