buttons freeze issue and scene issues [fixed]
Posted: 04 March 2015, 16:27
Issue 1:
The buttons on my Rack freeze frequently. It happens each time I use it. I need to turn-off the power of the unit for it to "come alive" again. What are possible causes?
Issue 2:
For scenes uploaded to the Rack the duration of the first step of a scene seems to be shortened after the first time of running the scene. For example, a first step of a scene starting at 00.00 has the duration of 7 seconds before it goes on to the next step. It plays correctly the very first time it is run after the Rack has been turned-on. If the scene is stopped and then run again, the Rack is now playing the step for only 1-2 seconds before it goes to step 2 and further. However, If I let the entire scene run to the very end and it loops back to the first step again - then the first step runs for the correct duration again...
Issue 2:
