Multiple shows
kahilzinger
Multiple shows
Post by kahilzinger »
Is there a way to save and store independent shows. For instance, if I am in venue "A" and I create a show, I see I can export it. Then, I go to venue "B" and I create a new show. Can I go between them and bring up each show on the import without affecting the default show?
Since I have a ShowXpress at the venue I normally work and a SweetLight at home, I see that the show data for both programs is stored in the user account directory. I guess I could create secondary user accounts for each venue but I would rather just re-import the venue I am in since I am using a second machine as a primary for the SweetLight venue and a backup for the ShowXpress venue.
Thank you.
Re: Multiple shows
Each show is stored in a different folder (like "default") in the folder "home_directory/TheLightingController/LightShows/default/".
When you choose another show from ControlBoard -> Settings -> current light show, you simply set another show folder.
Please note that you must restart ControlBoard, in order to load the new show (this problem will be fixed later).
kahilzinger
Re: Multiple shows
Awesome. Thank you.
