Master Fader > why from 0 to +100% ?
skyliner
I gues a lot of people will use the master fader function, but i dont understand the function -100% to +100% , for me it works only between -100% en zero. So the question is: what is the funcion for zero to +100% ?
Re: Explanation asked, master fader
The idea was you set the dimmer to 128.
Then, with the Master Fader, you can adjust the dimmer from 0 to 256.
Re: Master Fader > why from 0 to +100% ?
Well... in my case... i only put the dimmer to 256 value...
For future version, an option to choose the MASTER FADER range would be nice
skyliner
Aha......
, tested and it works.
Maybe for the todo list, for to insert this explanation into the tutorial.
