Edit duration in multiple steps [fixed]
Posted: 03 August 2010, 21:55
by BAF5P
Is there a way to edit the duration of mulitple steps in one scene. For instance, multiple steps with parcans fading in and out to different colors all set at 2.0 sec. I want to change all steps to 3.0 sec. I would think there is an easy way but I haven't found it.
Thank you in advance,
Eric
Re: Edit duration in multiple steps
Posted: 03 August 2010, 23:50
by chris226
If you want to change ALL of the step times in a scene:
1. Look a couple spots below your last step. You should see the total time for the entire scene.
2. If you click on that time you can change it and it will give you the option to "recalculate" ALL steps in the scene, so they will each have equal time.
In your case, multiply the number of steps you have by 3 (if greater than 59: convert result to time [hours/mins./secs.]) and enter that as your total scene time. If necessary, you can go back and change an individual step's time.
The easiest option, however, is just to change the buttons' speed setting in LIVE to 150%. I believe V6 will remember the speed setting even after you close and restart LIVE.
Hope this helps,
Posted: 04 August 2010, 02:25
by BAF5P
Makes perfect sense.
Thanks,
Eric
