mix scenes
grunter375
mix scenes
Post by grunter375 »
how would i go about uploading a generated scene for moving heads while also including other lights movements into (button#1,2,3,4) standalone memory. Im not quite sure how to create a scene including generator along with steps ?
Doing a scene in steps and uploading it to memory is no problem i just wanted generator as well as it looks way better with moving heads and saves me heaps of time.
Re: mix scenes
You can upload a timeline In StandAlone V7. You can put one scene per line (3 lines max).
Alternatively, you can use the function "Merge" in Editor > Steps, to merge scenes together.
grunter375
Re: mix scenes
Thanks for that i worked out the merge in Editor, but didnt know the timeline way. Thanks for the tip.
Dont know whether i should start another thread but was wondering why only 10 steps in generator ?
Re: mix scenes
Steps are memory consuming.
We had to fix a limit.
Return to “StandAlone”
