How to change name of a "step" in a scene? [fixed]
estelizondo
Hi, I tried but can't change the name of a step on a scene, I mean If I have 8 steps and for example change color 4 times I would like to name with the color name the step when it changes... there is a column names "name" but can't find right click or how to change it. Thanks!
Re: How to change name of a "step" in a scene?
In Editor you should be able to name steps in the upper middle panel. Just the same way you would select the step times. Just over to the left one block. Select the block and at the bottom of that upper middle panel, type what you want. When you're done save the step scene.
ashley.saylor@facebook.com
http://projectpinkband.com/
http://johnnywadband.com
