[6.24 beta] scene properties showing audio [fixed]
Posted: 28 July 2010, 12:06
by jaxx00974
This might even be a bug in earlier versoins of V6 but not tried it.. It is a bug in 6.24 and it is a weird one.
1. Insert wav file into time line.
2. insert your secenes.
3. Insert comments on the comments line.
Now, if you have insert a comment anywhere 'after' your last scene, what happens is your scene properties box becomes an audio properties box plus the loop box is not ticked and the loop function disables itself. you loose the Auto BPM, Manual BMP and Manual Speed Boxes also.
It is worth notingthat by putting any old scene as the last entry solves it only for a short while because after workingon a song the whole thing happened again half way through the song when I also deliberatly chose not to use any 'comments'. If you dont use comments then the Audio length grey bar was the faulty culprit so I had to make sure that I placed any old scene 'after' the audio event and comments, then I got back the correct properties box on all my scenes.
This relates to a previous post where mentioned I had problems with a rougue dmx signal plus irregular loop behaviour. I have only now realised how to recreate the loop/ proprties bug.
I hope this makes sense,
Regards,
Lee.
Re: Bug in 6.24 (scene properties showing audio proprties box)
Posted: 28 July 2010, 21:31
by Niffo
Thank you for your report, we have already fixed that bug following your previous report (with your lightshow) (an EXE is available somewhere in the "Support" computer and should be downloadable soon ;))
We're actually working on the "flash" side effect (who is caused by the first step of a scene) when a light scene is played in "no loop" mode in Live/TimeLine ...
Posted: 28 July 2010, 21:44
The fix is available in beta software folder ("fix_for_Windows.zip").
Posted: 29 July 2010, 09:24
by jaxx00974
Great news, thanks, I will try it out mid pm once I get back home and I will confirm.
Regards,
Lee.
