SlimPar 64 8 Channel 3D Not Strobing [fixed]
Posted: 03 May 2014, 02:57
by udjrentals
New to Showxpress, however not new to dmx/lighting. I have everything working great in 3D view but the strobing effect for my 30 SlimPar 64 RGBA in 8 channel mode. I've tried just about every setting and searched for an updated profile with no luck. any one know what I could be missing? I have some older 7 channel RGB Slimpars working just fine on all channel in 3D view.
- D512 Plus
- Wireless Trans/Rec'ers
- DMX Cabling
- Windows Visa/Dell Laptop
Re: SlimPar 64 8 Channel 3D Not Strobing
Posted: 03 May 2014, 18:30
Please post (or email us) the personality file.
We will check it.
Posted: 04 May 2014, 00:50
by udjrentals
Here is the supplied profile I'm using with that came with Showxpress. The Macro's don't work as well in 3D nor on physical light.
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 120
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 0
2DViewImage = Chauvet/SlimPAR 64.png
Channel = red
Red,0,255
Channel = green
Green,0,255
Channel = blue
Blue,0,255
Channel = color_macro
off,0,7 new_level,8,15 new_level,16,23 new_level,24,31 new_level,32,39 new_level,40,47 new_level,48,55 new_level,56,63 new_level,64,64 new_level,65,71 new_level,72,79 new_level,80,87 new_level,88,95 new_level,96,103 new_level,104,111 new_level,112,119 new_level,120,127 new_level,128,135 new_level,136,143 new_level,144,151 new_level,152,159 new_level,160,167 new_level,168,175 new_level,176,183 new_level,184,191 new_level,192,199 new_level,200,207 new_level,208,215 new_level,216,223 new_level,224,231 new_level,232,239 new_level,240,247 new_level,248,255
Channel = shutter
open,0,15 strobe,16,255
Channel = mode
RGB,0,31 pulse_effect_0%-100%,32,63 pulse_effect_100%-0%,64,95 pulse_effect_100%-0%-100%,96,127 auto_snap_transition,128,159 auto_snap_transition(3colors),160,191 auto_snap_transition(7colors),192,223 sound_triggering_mode,224,255
Channel = dimmer
dimmer,0,255
Posted: 05 May 2014, 07:07
This profile has 7 channels, and you said it should have 8 channels.
Please post a link to download the manuel.
We will check this.
Posted: 06 May 2014, 01:14
by udjrentals
So sorry, I posted the incorrect profile.
Filename: SlimPAR 64 RGBA (8CH).txt
ViewType = VIEW_TYPE_PAR_CAN
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewColor = 16777215
2DViewImage = Chauvet/SlimPAR 64 RGBA.png
Channel = red
Channel = green
Channel = blue
Channel = amber
Channel = speed_control
Channel = mode
RGBA mode,0,31 Pulse effect 0~100%,32,63 Pulse effect 100%~0,64,95 Pulse effect 100%~0~100%,96,127 Auto fade transition,128,159 Auto snap transition (4 colors),160,191 Auto snap transition (15 colors),192,223 Sound-active mode,224,255
Channel = dimmer
dimmer,0,255
Posted: 06 May 2014, 07:34
The two last lines :
Channel = dimmer
dimmer,0,255
must be replaced by something like ::
Channel = shutter
(not sure for values 15 and 16 ; we need the PDF manual)
Re: SlimPar 64 8 Channel 3D Not Strobing [fixed]
Posted: 06 May 2014, 22:45
by udjrentals
Okay, I found the problem. It was on channel 6 that needed to change
To:
Channel = shutter
no_function,0,15,strobe,16,255
One would figure Chauvet would have the correct profile with the software. Now it's getting the Modes and Color macros to work.
Manual located here: http://www.chauvetlighting.com/products ... ev1_WO.pdf
Thanks for the help!
Posted: 07 May 2014, 13:10
Thank you for the report.
We will correct the profile in the software.
Posted: 07 May 2014, 13:31
by Allan
Hi Udjrentals,
Thanks for the information. I will have it fixed and part of the next software release.
