Page 1 of 2
How to change the font for the text ?
Posted: 02 December 2013, 01:03
by zkflow
I have this problem. I'm using a setup with low number of pixels, and when i try to use text function, generates to me a lot of pixels hard to read in the fixtures... for me the best font to do configuration with low number of pixels its "SMALL FONTS REGULAR" because only generates the exact pixels (without innecesary shadows) for a good reading.
THANKS!
Re: HOW TO CHANGE THE FONT FOR TEXT?
Posted: 02 December 2013, 02:49
by Pink LD
This is just a work-around:
-upload the picture to your button in Live
Now the size of the buttons vary depending on how many buttons you have on each page so you'd have to play and tweak to get a desired result, but it may help in the interim until support can give you a better, clearer answer/solution.
Re: How to change the font for the text ?
Posted: 02 December 2013, 18:55
We suggest you to create a picture with your "chosen font" text and transparent background (.png).
Then you can try the "Picture motion" effect.
Posted: 02 December 2013, 18:57
by Pink LD
What is a "picture motion effect"?
Posted: 02 December 2013, 21:32
This is an effect in Pixels, to show and animate pictures on LED's fixtures.
Posted: 02 December 2013, 21:35
by Pink LD
Ok, I don't use Pixels as yet. But O have some fixtures slated for a NES lighting/set design in the new year that I will need Pixels for.
Posted: 09 December 2013, 04:38
by zkflow
support wrote:We suggest you to create a picture with your "chosen font" text and transparent background (.png).
Thanks! It's good but takes a lot of time... and my suggestion its to improve the text function for better results in real-time
THANK YOU!!!!!!!!!!!!!
Posted: 09 December 2013, 04:45
by zkflow
ok, works great with small words (or initials, in this for my production company "RV")... now when i try to improve a larger text "happy birthday anthony" (for example) pixels "compress" the PNG image... now what i can do?
THANK YOU
Posted: 09 December 2013, 04:52
by zkflow
ok, for those who dont get whats the problem, this is what pixels should show text for easy-reading in the fixtures.
Uploaded with
ImageShack.us
For me the solution its in the programing change the default font to SMALL FONTS (a system font)
Posted: 09 December 2013, 05:02
Thank you for the clear explaination.
We note in the ToDo list: "Check possibility to change (multi-OS) font".
