midi trigger
davem400
midi trigger
Post by davem400 »
hi guys :)
nice to see the midi trigger implemented so far i have been unable to make it work has it seems not to be able to see any midi from any of my inputs am i just missing it which wouldnt surprise me lol i have been able to use midi from various inputs in the past coming from Cubase my sequencer and show express v5.21 but i have been unable to make that work on windows 7 so have been watching the progress on this version closely as i have about 8 weeks to go before i start doing gigs and was really hoping i could use windows 7 instead of xp
any help is greatly appreciated
thx
Dave
Re: midi trigger
Midi is not yet working in this beta version (viewtopic.php?f=34&t=231) but will come very soon
davem400
Re: midi trigger
Post by davem400 »
many thx for your reply
jaxx00974
Re: midi trigger
Post by jaxx00974 »
I also had a similar problem which was solved using an app Called midipicker.
It may not be related perhaps worth a try.
http://www.softpedia.com/get/Multimedia ... cker.shtml
Regards,
Lee.
Re: midi trigger
Midi is available in version 6.22 beta.
fedo
Re: midi trigger
Post by fedo »
bonjour même soucis que mes voisins la version 6.21 ne reconnait pas mon interface midi
quand sera dispo la version 6.22
a part cela c'est une excellente avancée nous avons actuellement quatre interfaces sweetbox !! je prêche la reconversion de sunlite à sweetlight et les techos ne regrettent rien
Re: midi trigger
Vous pouvez dores et déjà tester le midi dans la version 6.22 beta disponible ici : viewtopic.php?f=35&t=266
Cordialement.
fedo
Re: midi trigger
Post by fedo »
je viens de télécharger la version 6.22 et mon clavier midi n'est toujours pas reconnu !! alors qu 'il fonctionne parfaitement en version 5
dans la version 5 il y a trois menu déroulants : le canal la note et l 'interface midi alors que dans la version 6.22 ce troisieme menu n'est pas présent
mon clavier est un nanokey de chez korg clavier midi en usb
que dois je faire ??
merci
Re: midi trigger
Dans la version 6, le paramétrage de l'interface se fait à partir de ControlBoard => "DMX & Midi Patch"
fedo
Re: midi trigger
Post by fedo »
effectivement ca fonctionne en revanche quand on appuyait une touche midi dans la version 5, elle s affichait dans le midi trigger donc on connaissait de suite son n° pour le rentrer dans le menu déroulant alors que dans cette version il faut connaitre le n° de la note midi d avance on a aucune indication entre la note midi comme C4 et son n° exemple 72
je suis obligé encore d aller dans la version 5 pour connaitre l ' équivalence note midi / n°
Return to “Buttons”
