The Screen "Set Channel Infos"
tomrbland
Post by tomrbland »
Firstly I think this should be titled "Set Channel Info" as you are setting one value for one channel - not plural.
Secondly would it be possible to order the columns so that it is easier to find the channel name.
for example have the first column devoted to general fixture properties such as: Shutter, dimmer, beam, iris, X, Y etc. The second column devoted to colour: Red, Green, Blue, Cyan etc. The third devoted to beam shape: Gobo, gobo rotate, prism etc. Then the 4th for 'others' such as: Fan, Laser, truss motor.
This would make building fixtures so much quicker. I was going to do a quick demo of how to build fixtures in V6 but decided to wait until it looks a bit more user friendly.
Cheers
Re: The Screen "Set Channel Infos"
Added in the TODO list.
tomrbland
Post by tomrbland »
Thank you :)
Return to “Setup”
